jump/charging Optima dry cell
Old Feb 24, 2009 | 04:26 PM
sharkthehunter77's Avatar
sharkthehunter77
Default jump/charging Optima dry cell
can you jump or for that matter, recharge an optima blue top dry cell,..like you would any other normal battery?
Old Feb 24, 2009 | 04:50 PM
gdc's Avatar
gdc
You can jump it, but it's better to charge on deep cycle w/ a charger. Most chargers have a switch for regular/deep cycle.
Old Feb 24, 2009 | 08:24 PM
DanZ51's Avatar
DanZ51
Hey, I've been down this road...
Here's some good info, funny it's not one Optima's own we site
http://www.batteriesareus.com/index....id=2&chapter=0
Old Feb 24, 2009 | 09:19 PM
daytonaer's Avatar
daytonaer
Interesting link.
I have had luck charging an optima with a battery-tender for a few days. This is a 1.5 amp w/float charger essentially.
Optima does warn that you should NOT charge your battery on a regular charger and to only use a low amp trickle charger. The suggested link of blasting it for a few minutes and letting it cool sounds like it would work, but if you don't have the time or patients I would just stick it on a trickle charger with a float mode for a few days.
Be careful of a regular charger or the amp output of a "deep-cycle" charger switch.
To jump/charging Optima dry cell
