difference between headers with egr and without
Old Feb 28, 2009 | 01:01 AM
mavidatt's Avatar
mavidatt
Default difference between headers with egr and without
Is it better to get headers with egr or not? I dont really have no idea on what it is? Not very experienced with this, never have installed headers on any vehicle before, have an 89 vette, which is pretty much stock, but soon will have a zz4 in it and wanted to know if i need headers with or without egr?
Old Feb 28, 2009 | 01:11 AM
slickfx3's Avatar
slickfx3
their saying the recirculation of the exhaust helps offset pinging and if you are in a state that requires it on a visual inspection, there is no way around it
Old Feb 28, 2009 | 02:07 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Are you set on re-installing the stock intake?
Do you have emission's testing in your area? Do you care (strongly) about it?
Old Feb 28, 2009 | 11:03 AM
c4cruiser's Avatar
c4cruiser
If you get headers without an EGR hookup, you are going to have to "
fool" the ECM into thinking the EGR valve/switch is working. Without the switch in place, you will get a EGR code and the SES light will stay on. If you remove the EGR valve from the intake manifold, you will have to get a block-off plate.
The Hedman Elite #68487 has hookups for both AIR and EGR. If you have to have an emissions inspection, get those.
In any event, a ZZ4 crate motor may not pass any required emissions testing if there is no AIR or EGR installed, headers or not.
You should definitely check your state's emission laws before going too far with mods and find out later on that the car can't be licensed if it won't pass any testing (sniffer or visual).
Old Feb 28, 2009 | 01:23 PM
383vett's Avatar
383vett
Correct me if I'm wrong. I thought the egr valve and system is built into the intake manifold. Exhaust gasses are allowed to pass throught the egr valve and dilute the intake mixture going to the combustion chamber. This is all done within the the intake. I think you are referring to the air pump which injects air into the exhaust manifolds or headers under certain circumstances. They are both different and separate systems.
Old Feb 28, 2009 | 02:12 PM
mavidatt's Avatar
mavidatt
dont really care about emissions tests or anything like that. If i get them without then they should work fine even if the code is triggered it shouldnt mess with my vehicle though?
Old Feb 28, 2009 | 03:23 PM
Demonic85's Avatar
Demonic85
Its entirely in the intake manifold on early L98's and older SBC's but they switched to a setup using a pipe that goes from the intake manifold to the exhaust manifold on later years ('87 or '88 I think).
To difference between headers with egr and without
