Heim Joint Maintenance
Old Mar 1, 2009 | 02:54 AM
dan6712cc's Avatar
dan6712cc
Default Heim Joint Maintenance
I have several heim joints on the rear end of my '94 and would like to know the proper way to clean and lubricate them. Is soap and water ok to clean or do I need a de-greaser? What lubricant should I use if any?
Old Mar 1, 2009 | 06:38 AM
Churchkey's Avatar
Churchkey
To clean I used WD40 on the oval track cars. Lubed them with lubriplate spray lube using the straw.
Do you have grease fittings? If so then a standard chassis grease works well.
There are dust covers available in many sizes to keep dirt out of the bearings if your using heims on a street driven machine.
Old Mar 1, 2009 | 08:42 AM
dan6712cc's Avatar
dan6712cc
They dont have grease fittings, they look like this:
Old Mar 1, 2009 | 09:13 AM
StealthLT4's Avatar
StealthLT4
I'm not sure about cleaning, but I've heard that a dry lubricant works best. Oil apparently will just attract dust/dirt into the fitting and cause premature wear.
Old Mar 1, 2009 | 11:11 AM
Aardwolf's Avatar
Aardwolf
I can't tell from the picture but they may have a teflon insert, ask the maker.
Old Mar 1, 2009 | 01:26 PM
dan6712cc's Avatar
dan6712cc
I emailed them several times with no reply, they are Guldstrand. Pretty bad customer service considering how expensive these pieces are and that I bought several pieces from them.
Old Mar 1, 2009 | 01:29 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
for the street, you'll want to run boots
http://www.sealsit.com/rodendboots.asp
Old Mar 1, 2009 | 01:41 PM
Aardwolf's Avatar
Aardwolf
Call and talk to Craig, I talked to him several times last week. I generally don't try and email companies as I've found they aren't real good with email questions. Maybe the mail gets accidentally sorted into spam, I know on my Yahoo mail I find stuff that shouldn't be in there!
Old Mar 1, 2009 | 02:50 PM
dan6712cc's Avatar
dan6712cc
I've already been running them without covers on the street for a while so that's why I'd like to know what to clean and lube them with.
Old Mar 2, 2009 | 11:16 AM
Aardwolf's Avatar
Aardwolf
I called them for you, they are the type with the Teflon insert that doesn't require lube. Just look at the eyelet there will be a plastic looking strip in there. Putting lube on it can attract and stick on dirt. As for cleaning it, WD40? I ordered a set of front links while I was at it. Probably cost $50 to build but I'm running out of time.
Old Mar 2, 2009 | 02:23 PM
dan6712cc's Avatar
dan6712cc
Thanks, that makes things easy as far as maintenance
Old Mar 2, 2009 | 03:07 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Brian -
you bought the Banski Motorsports links correct? Did you get boots from sealsit? What size did you get? I am considering getting some of the Baski links as well.
Old Mar 2, 2009 | 04:15 PM
BrianCunningham
I've got the Banski stuff, but I haven't install it yet.
Have to wait until my car thaws out
Old Mar 3, 2009 | 08:37 AM
BrianCunningham
I emailed Tom (astock) about them
Hey Brian,
To be entirely honest, I ordered some of the seals-it boots and tried them and was really disappointed. I wouldn't recommend them if anyone asked me.
Tom
So much for that idea.
Old Mar 3, 2009 | 08:43 AM
StealthLT4's Avatar
StealthLT4
I've been thinking about doing the Banski trailing arm kit on my street car, but that would be a pretty bad idea if boots won't work. Is there any solution for a heim-jointed DD?
Old Mar 3, 2009 | 09:43 AM
Kubs's Avatar
Kubs
It must just have to be a weekly/monthly thing to clean them...
Old Mar 3, 2009 | 10:12 AM
BrianCunningham
I was kinda counting on the boots
I know CentralCoaster installed heims with teflon seals, and it's his DD, though that's in SoCal.
To Heim Joint Maintenance
Old Mar 3, 2009 | 10:54 AM
Sidney004's Avatar
Sidney004
You need to use a dry lubricant from day one. I use graphite.
Old Mar 3, 2009 | 12:51 PM
Kubs's Avatar
Kubs
Pardon my ignorance but what is a dry lubricant? How does one apply it? and what makes it work?
Old Mar 3, 2009 | 12:53 PM
Kubs's Avatar
Kubs
