Dana 36 Guru's step inside
Old Jan 2, 2010 | 11:32 PM
jhammons01's Avatar
jhammons01
So the D36 is back on the bench at this moment. If My local differential expert would come back to work, I'd be able to finish this one off.
Old Jan 2, 2010 | 11:41 PM
jhammons01's Avatar
jhammons01
Does anyone know how much oil should have been in there? I am about to measure what came out
Old Jan 3, 2010 | 06:21 AM
aboatguy's Avatar
aboatguy
1.5qts/1.42L and 4 oz/118 ml of limited slip additive
However, some recommend double the LSD additive
http://forums.corvetteforum.com/c4-g...-diff-oil.html
Old Jan 3, 2010 | 08:44 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
Originally Posted by rodj
we build diffs all the time at the shop where i work,and randys is a little high on the price,but i personally dont think the quality can be beat.plus they seem to always have the hard to find parts for my d36.
Old Jan 3, 2010 | 10:43 AM
jhammons01's Avatar
jhammons01
Thanks, that is what came out of it. And yes I used 8 oz of LSD additive...
this time I am going to put a drain plug in it.....
Old Jan 3, 2010 | 11:51 AM
pologreen1's Avatar
pologreen1
Originally Posted by jhammons01
Hey thanks.
What is that Kit I see on Ebay for $95???
It has two bearings
http://cgi.ebay.com/ebaymotors/CHEVR...RCHQ3aUSQ3a101
I'm not saying you are wrong 'cause I know nothing...I'm just looking to see what the angle is.............
I bought a complete rebuild kit for like 130 something at the time for DTS, includes everything even lubes and stuff.
Old Jan 4, 2010 | 02:10 AM
jhammons01's Avatar
jhammons01
^^I did the bearings and seals this summer, I am only after a clutch pack at this time. That carrier is staring at me right now.
I'll know more after about 10am tomorrow.
Old Jan 4, 2010 | 02:12 PM
jhammons01's Avatar
jhammons01
So....John at:
J & S Gear Co.
18222 Gothard St. Unit A
Huntington Beach, Ca. 92648
(714) 841-4545
He of course had the clutch pack in stock.
Two plans of action:
One, the clutch pack can be "Re-shimmed" if they are not too worn out. The Grooves are the tell tale sign. This will cost me $100 for the service of removing the carrier re-shimming and remounting the carrier
Two, The clutch pack is too worn to just shim.
same thing as above with the exception of installing new clutch plates....$250
He was 98% sure he could do the re-shim.....
And of course John will have it ready for me Tomorrow afternoon, 24 hour turn around.
That guy is GOLD! Any local would be wise to jot down that info for anything concerning your D36 or D44....or any other one. Especially performance diffs.
Anyone not local should keep his number....super nice, has parts in stock....The only one that new that there are TWO D36s for our vettes...(watch out...do you have an early version??? Would you know to ask?? The person you asked...did they know about this???)
Old Jan 4, 2010 | 03:25 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
I just replaced a Dana 44 clutch pack yesterday.
You have to remove the clutch pack to inspect the groves remaining on the clutch packs disk set, by reshimming the clutch pac without removing and inspecting the grooves remaining in the set, might only be a short term temporary fix.
I would just swap out the clutch, so you don't have to do this again.
Old Jan 5, 2010 | 07:16 AM
c-4 lhozwalte
So....John at:
J & S Gear Co.
(714) 841-4545
not surprised i didnt know about the two versions of d36.is there a year break,or some other way to tell?
Old Jan 5, 2010 | 09:35 AM
jhammons01's Avatar
jhammons01
^I'll ask this afternoon wen I pick mine up
Old Jan 5, 2010 | 05:54 PM
jhammons01's Avatar
jhammons01
OK, The early model D36 is in all 84-91s and the later one is 92+. And the only difference is the Stub axle bearings
So my new clutch pack is installed and ready to go $200 out the door.
