tranny swap
Old Mar 1, 2009 | 10:50 PM
ward6903's Avatar
ward6903
1st Gear
Default tranny swap
replaceing my automatic with a six speed manual any body know what i need to do with the wires that pluged into the shifter the manual shifter has no wire connectors and i am sure something will need to be done with it
Old Mar 1, 2009 | 11:33 PM
rodj's Avatar
rodj
One set are for the park /neutral lockout ; goes to the clutch switch or can be joined together BUT YOU HAVE NO LOCKOUT
Other set are for backup light ; need to be extended through floor to switch on drv side of trans.
There is a 3rd pair that tell the ECM car is in park / neutral; no sure were they connect to on ZF6
