AC Delco Water Pump Question
Old Mar 8, 2009 | 01:33 AM
LT1CORVETTE's Avatar
LT1CORVETTE
Default AC Delco Water Pump Question
1996 Z51 LT1 Corvette
Long story short, I broke the upper metal heater hose connector tube that comes off the top of the water pump while attempting to change my heater hoses today, so it looks like a new water pump is on the to do list.
It appears rock auto has the best price on an ac delco replacment and shows it comes with new gaskets. Do these come with the inlet thermostat housing and a new thermostat? There picture is showing it without, but most of the other magazines show it with. Any knowledge would be appreciated. Thanks.
Old Mar 8, 2009 | 03:31 AM
zzpw3x's Avatar
zzpw3x
I've always had prompt responses when I've asked rockauto questions like that one. Send customer service an email.
Dale
Old Mar 8, 2009 | 01:34 PM
LT1CORVETTE
Dale
Good to know. Thank you dale.
Old Mar 8, 2009 | 01:48 PM
MikeC4's Avatar
MikeC4
I don't know about Rock Auto prices on WP's, but "thepartsladi" is who I use for new AC-Delco WP's. They come complete with new T-stat, T-stat housing and gaskets. I use Rock Auto for my non-vette applications and they have never let me down.
http://search.stores.ebay.com/Thepar...346802QQsofpZ0
Old Mar 8, 2009 | 01:56 PM
SunCr's Avatar
SunCr
Isn't that a threaded tube? If so it's servicable for a couple of bucks.
Old Mar 8, 2009 | 02:21 PM
LT1CORVETTE
I am not sure. I am planning to pull and take apart the water pump today if time allows. Here is the tube in its current state.
Old Mar 8, 2009 | 02:31 PM
MikeC4's Avatar
MikeC4
that's just a compression fit tube. You should be able to tap it in good and snug using rubber mallet.
Your WP appears to be clean, is there any other problem you are having other than that fitting popping out ?
Old Mar 8, 2009 | 03:08 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I had one, still in Vette, come out. I JB welded it back in.
Old Mar 8, 2009 | 04:39 PM
LT1CORVETTE
Thank you so much guys. Saved me buying a new pump and some bloody knuckles putting it in. I'll put some some jb weld on it, tap it back in and report back. I am not a strong guy, so how I managed to (break) it has been eating at my mind.
No other problems what so ever with the water pump (its only 3 years old and has about 8k miles on it)
Old Mar 8, 2009 | 04:56 PM
steve40th's Avatar
steve40th
I had that one blow out on the racetrack. It was quite the ride
Old Mar 8, 2009 | 06:09 PM
MikeC4's Avatar
MikeC4
This is an excellent idea. May I suggest that you use medium grit sandpaper to scuff up the part of the fitting that goes inside the WP housing. Fom the picture, it appears to be very smooth. The sandpapaer will put small grooves on this fitting allowing the JB Weld to get a better grip. If the inside hole in the WP is smooth, I would also try to sand a little bit of that area as well.
Old Mar 8, 2009 | 09:07 PM
SunCr's Avatar
SunCr
Didn't know GM went to a compression fitting - everyone I've seen is threaded and they come in a couple of lengths. Most Dealers seem to have them hanging near the Counter (next to the Coolant Sealant Tabs).
Old Mar 8, 2009 | 09:21 PM
steve40th's Avatar
steve40th
You could always get a brass fitting and screw it in, with RTV, if your concerned. But JB Weld with a scuffed factory fitting will work too.
Old Mar 9, 2009 | 12:31 AM
LT1CORVETTE
Thanks for all the help gentlemen. I did not get around to installing it today, but will hopefully get it done tomorrow evening utilizing the scruff up and jbweld approach.
Old Mar 9, 2009 | 02:55 PM
MikeC4's Avatar
MikeC4
For whatever reason, the LT1's WP tubes are compression fit. The tube that he is holding in the first picture is the entire tube, it has not broken off at the thread line, because there are no threads.
In the second pic, you can see(almost) that the bore where this tube inserts is smooth. I have tried removing(unscrewing) this same tube from an old LT1 WP I had lying around, and it just spins. I took off the T-stat and saw that the inside of the bore for this fitting is in fact smooth.
To AC Delco Water Pump Question
