I need some advice from people(or know someone) running solid cams in their blown Ltx engine. I did a search but came up empty. It doesn't need to be streetable.
I'm currently running a 383 with a 230/242-.544/.576 hydraulic roller cam with the TPIS/AFR head. I also want to change these heads for either the 210cc comp. AFR heads or the 227cc comp AFR heads. But I read that for the 227cc heads there are 'more' things to be changed. Any one knows what these 'things' are?
OK...thanks....
The biggest thing would be the .050 offset rockers. Other than that, it shouldn't be a big deal.
As far as running a solid roller on a LT/X motor, I don't see it being a big deal. They are so close to a first gen, it shouldn't be a problem. And with their reverse cooling, you can usually run more compression. I did a 396 LT4 with 12.2 compression, a 230/236 114 lsa cam, and it runs fine on pump gas (91 octane here), and will run a 175 shot of nos also on pump gas. But we are 6000-9000ft DA, and we can run more compression up here in our thin air.The LT/X reverse cooling was a good idea, the heads get cooled before the block, which is a bonus in preventing predetonation.
One last thing would be the need to flycut the pistons. But that depends on how aggresive your cam is, and what pistons are in it right now. Alot of the upper end pistons JE ect, have generous valve releifs that probably wouldn't need flycutting.
the brodix 227 heads have standard valve spacing but you would have to change or modify your intake.
I ran the comp cams solid roller blower cam in my turbo SBC.
it wasnt optimal for the turbos but I am saving it in case I ever build a blower engine. at 255/262 I really had to spin it to make it work.
probably better suited to blown drag only, and more converter.
I'm having good luck with the same set of crower lifters on both cams.
just make sure you have enough valve spring for the rpm and boost.
That's what I read on the AFR site. You need either .050 offset rockers or shaft mount for the 227 heads. But are the 227 heads worth all those extra expenses(rocker arms, flycutting) compared to 210 comp heads? They claim the 227 comp heads flows 315cfm@.600 lift while the 210 comp heads flows 308cfm@.600 lift, so is that a big difference????
I took a look at their blower cam, but they say the RPM range is 3000-6500rpm and I need more rpm, say 7200-7500rpm.
if you want to run the solid roller (and as you stated, you want more rpm) then the shaft mount would be a more "ideal" valvetrain combo. Otherwise, you should stick with hydro cam, and "traditional" valvetrain.
I too am considering a solid roller cam for the engine i will eventually build. But i was also planning on running a shaft mount rocker combo.
still split between going "all out" 396, or sticking with the traditional 383 cubes... i find myself loosing sleep over 13 cubic inches, LOL
when i talked to TPIS, Jim told me he runs a solid roller in his f-body LT-x engine. He did mention that adjustment might be necessary, but to what extent i don't know... he hasn't even put 5,000 miles on that combination (and hasn't needed adjustment thus far).
