how do i set up a mechanical fuel pump?
Old Mar 8, 2009 | 09:17 PM
DrEvil11417's Avatar
DrEvil11417
Default how do i set up a mechanical fuel pump?
I have a '90 motor in an '86 pump and i'm having too many issues regulating the in tank pump down to 5psi for the carb... i want to run a mechanical pump - i've read that my hot cam has the lobe for it -
how should i set up the pickup in the tank? can i run a hose from the metal line right to the bottom of the tank?
Old Mar 8, 2009 | 09:48 PM
SunCr's Avatar
SunCr
Assuming it's an L98 block, remove the cover and bolt it on.
Old Mar 8, 2009 | 09:57 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You'll need a fuel pump mounting plate, and a pushrod. The mechanical pump should pull the gas right through the in tank pump so you can forget rigging a pickup.
Old Mar 8, 2009 | 10:14 PM
DrEvil11417
doesn't it bolt right to the block?
Old Mar 8, 2009 | 10:17 PM
Ryan59's Avatar
Ryan59
Mount an electric pump back by the tank that has a working pressure of 8psi. Pumps do not like to pull. So mounting it back as close to the tank as possible makes the pump push fuel rather then pull.
Old Mar 8, 2009 | 10:20 PM
rodj's Avatar
rodj
Some of the 1 pce blocks I have seen don't have the pushrod hole drilled out even though the pump mount is cast on.
Old Mar 8, 2009 | 10:39 PM
redrose's Avatar
redrose
fwiw, early 3rd gen F-bods ('86+ IIRC) with carbs had severe 'vapor lock' problems and GM installed an electric in-tank 'booster' pump in addition to the mechanical block-mounted pumps.
just change your existing pump to an 84 vette in-tank pump that won't push more than 15 psi.
Old Mar 8, 2009 | 10:43 PM
DrEvil11417
that's what's in there right now, my regulator is the holley one for 4-9psi output and i think it cooked the diaphragm already since it's showing 13psi at the carb no matter what
Old Mar 9, 2009 | 12:28 AM
jeffp1167's Avatar
jeffp1167
do what redrose said. order a 1984-1986 F-body L-69 booster pump. they only made about 5psi. The electrical connector might be a bit different and you will have to add a bit longer rubber hose between the pump and the sending unit but it will fit no problem. I think that pump alone could support the carb.
Old Mar 9, 2009 | 07:06 AM
Happydad's Avatar
Happydad
Just a couple of questions.....Is your FPR a three way?? You need to return fuel back to the tank if useing a stock 86 FP...Also the stock return line is too small to handle the flow back to the tank...Now, you could reverse them,but you'll have to relocate the fuel filter(remove add a line and re place it somewhere else) ...Another thought...Does your cam support a mech fuel pump?? Some Hot Cams don't even have the lobe(Double check that)...Just some Thoughts
Old Mar 9, 2009 | 08:00 AM
DrEvil11417
the pump is an stock '84 pump i swapped in.. as far as I know all the HOT cams have the lobe, is there any way to be sure aside from taking the plate off?
Old Mar 9, 2009 | 10:10 AM
Midnight 85
You will have to pull the plate off the block and stick something in the pushrod hole then turn the engine over and see if the object moves. If not then your cam has no fuel pump lobe. If this is the case then as was stated earlier another electric pump made for carb pressures would be the way to go.
No, the block is machined with an opening the shape of the cover plate and the pump is shaped similar to a diamond, you have to have the pump plate on there first. Summit has them.
To how do i set up a mechanical fuel pump?
