asr/abs lights plus funny noises
1992, automatic. What was a clunk in the rear end everytime driving off after stoping, has now become a light show in the display, without the clunk. When I back out of the driveway, going about 10 feet, I hear a loud zipper noise coming from the back, guessing something with the abs (pump?), as soon as I hit the brakes the noise goes away and the service asr/abs lights come on, no other noise. I can feel the pedal moving a bit under my food when it makes the zipper noise. It's the same noise every chrysler made since 2000 when the you put the tranny in gear. The lights started right after I greased the pins for the rear calibers, which stopped the clunk.
Doing a lot of reading, it seems the abs will only come on after going at least 3mph, so that's my 10 feet backing real slow and when the clunk use to happen.
Now the real pain, no CCM codes, no module 9 codes, no codes anywhere, just the funny noise and lights. Any ideas
Sounds to me like you have an issue with one of the rear wheel speed sensors, make sure you didn't damage one when working on the calipers or accidentally pack the tone wheel with grease or debris.
