Should bore my engine over?
Old Mar 9, 2009 | 12:25 AM
mavidatt's Avatar
mavidatt
Default Should bore my engine over?
As of right now I am set on getting a zz4 base engine and using my own intake and adding an exhaust and stuff later on. But was wandering if it would be better to just have my original engine bored over. Bout how much would it cost to have this done, how much power gain should i expect over stock?
Old Mar 9, 2009 | 07:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
If you are buying a new one dont bother boring it further, you wont notice any difference at all.
Old Mar 9, 2009 | 08:05 AM
rodj's Avatar
rodj
The ZZ4 is a " better" version of your '89 roller cam engine; same heads , 4 bolt block.With TPI about 300ish HP
Choices
Buy ZZ4 long block ;$3300
http://paceperformance.com/index.asp...&ProdID=194848
You can also recover some of your outlay by selling your old engine.
Buy ZZ4 shortblock $2500 ,reuse your bolt on parts and rec your heads w/ ZZ4 springs.
http://paceperformance.com/index.asp...D&ProdID=22861
Recondition ( bore out ) your whole engine and install new cam.Prob find better than ZZ4 cam.
You need to get some local pricing on costs of recond and assembly of your engine so you can do a cost analysis
Old Mar 9, 2009 | 11:51 AM
ZLX's Avatar
ZLX
About $10 per hole.. $80.. you won't see much power increase at
all, if any, by boring only.
There's alot of ways to spend the same amount of money you'd
spend on a ZZ4 and end up with more power.
The ZZ4 uses L98 heads..which you already have...
the other differences... 10:1 compression and the ZZ4 cam.
ZZ4 has upgraded crank and 4 bolt block..but those don't make
you any power..and at the 350 to 400hp power level are not nessasary. Plenty of 400hp Street Stocker racers at 400-425hp
at 6000rpm on 2 bolt blocks.
1 Cam- Run the ZZ4, LT4Hotcam, ZZ9 or other cam.
2.Heads- have yours pocket ported locally, Port Pros in Austin,
or Chapman Racing in Utah other choices.
3. Pistons- run Gas Ported pistons that give you 10:1... you
should be able to find some Sportsman/Claimer pistons that
achieve this. ZZ4 has 10:1 but aftermarket Gas Ported will yield
a better seal for less $. SRP, Probe, Mahle, JR Motorsports,
Speedway Motors, etc.
4. Spend remainder on improving your Intake and Exhaust...Stock TPI
intake is an air choker... buy a set of decent headers and mufflers.
The ZZ4 makes 350hp carbureted... You'll need to get your
top end breathing to match that.
Old Mar 9, 2009 | 11:55 AM
Aardwolf's Avatar
Aardwolf
It makes no sense to me to pay for another block when you can use yours. I'd rebuild the block that I already paid for.
Old Mar 9, 2009 | 01:53 PM
Elephanthead's Avatar
Elephanthead
Yeah, unless something is really wrong with your block, you need a machine shop, not a new engine.
Old Mar 9, 2009 | 05:28 PM
Pete K's Avatar
Pete K
If yoyu drop off a bare, used block at the machine shop, it normally runs $600 or so to completely recondition it. They normally do the following:
Hot tank
shot peen
Magnaflux
Line hone
Bore
Finish hone with torque plates
square deck block
Install cam bearings
install freeze plugs and oil galley plugs
If you are only looking to bore and hone with torque plates, $150-$175 is typical.
Old Mar 16, 2009 | 09:10 AM
mavidatt's Avatar
mavidatt
What would you recommend for upgrading the tpi intake?
Old Mar 20, 2009 | 11:42 PM
Rogue1's Avatar
Rogue1
TPIS components:
Big Mouth lower plenum
Large Tube Runners
Port-matched upper Plenum
52mm Throttle body
Level 3 or 4 Chip
Old Mar 21, 2009 | 01:15 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you are changing the cam anyway pick the right cam and put a Mini Ram on it. A ZZ9 will work as will other cams. You will need a custom tune.
To Should bore my engine over?
