Do These Fit on a '85
Old Mar 9, 2009 | 06:58 PM
65tripleblack's Avatar
65tripleblack
Default Do These Fit on a '85
Will the AFR ZR-1 replica REAR (11 1/2" x 17") wheels fit my '85? I have Z51, which means that the wheels are all 9.5" x 16".
There is about 1 1/2" clearance between the inner edge of the original tires, and the mufflers. There is less than 1" clearance between the shock mount and the inner edge of the rims.
Has anybody actually mounted these, along with the 315/35-17" tires? If so, what can you tell me?
Thanks in advance.
Old Mar 10, 2009 | 09:36 AM
jmrl98's Avatar
jmrl98
I have 04 ZO6 wheels on my 85, and I think I have the 1" adapters. If not the 1", they're 1.25". I remember ordering 3/4", and they didn't help at all. I had to go to one of the local wheel shops, and they took care of me. It was while ago, and I'm not at home to measure. I can measure later today and get back to you if you'd like.....
Old Mar 10, 2009 | 09:39 AM
LD85's Avatar
LD85
Find out the offset first.
I have replica ZR1 wheels made for the 85 offset.
Old Mar 10, 2009 | 09:51 AM
65tripleblack
1985 (z51)
front & rear 16"x9.5" 38mm (6.7" backspacing)
Goodyear Eagle VR50, P255/50VR-16
Old Mar 10, 2009 | 09:52 AM
65tripleblack
Yes............I see the Z06 wheels are available as well. They're nice.
Chrome C6-ZO6 Style, 18 inch, Low Offset
18x9.5 inch , 5x4.75 inch 40mm
Chrome Wheels
# Fits 1984-1987 Chevy Corvette
# Brand New Reproduction C6-ZO6 Style Wheels
# Center caps are included.
Old Mar 10, 2009 | 12:21 PM
Demonic85's Avatar
Demonic85
Then yes they will fit as long as it specifies '84-'87 which have a +38mm offset compared to '88 and up +56mm.
Old Mar 10, 2009 | 12:53 PM
pearlvett's Avatar
pearlvett
Just make sure the offsets are right and theyll work fine.
To Do These Fit on a '85
