AIR pump delete question
Old Mar 12, 2009 | 11:26 AM
johnno!'s Avatar
johnno!
Default AIR pump delete question
Hey guys, I want to start out by saying I did attempt to search but I think the search function is messed up. I have an 86 that I would like to delete the air pump from, the AC is already out and at one point I saw a thread that had a standardf rotation waterpump, no tensioner, no air pump and an adjustable threaded rod that went from the ALT to the manifold to tension the deal. Does anyone have a part number for that rod off hand? or a link to the thread or pics would be great too!
thanks
John
Old Mar 12, 2009 | 11:32 AM
Aardwolf's Avatar
Aardwolf
I used the rod brace from the A/C, it was nearly a perfect fit. I had to slot the bolt hole just a little. Also I've ran it awhile with the reverse rotation pump turning normal rotation, with no over heating. I do have a normal rotation pump to install, mainly for fear of cavitation under my increased (6000 RPM) rev limit. You can use a threaded rod but it isn't needed.
Old Mar 12, 2009 | 12:44 PM
johnno!'s Avatar
johnno!
thats perfect! thanks so much. do you remember what size belt you used?
Old Mar 12, 2009 | 12:58 PM
Aardwolf's Avatar
Aardwolf
When I measured it looked like a 53" to 56" would work. I went with a 55" from Summit for $15.
Part Number: GTR-4060550
Belt Style: Serpentine
Number of Belt Ribs: 6
Belt Length (in): 55.00 in.
Old Mar 12, 2009 | 01:16 PM
johnno!'s Avatar
johnno!
I'll have to go find my AC rod, I know 88 got a diffrent compressor, but hopefully the support rod is the same. thanks again!
John
Old Mar 12, 2009 | 04:31 PM
johnno!'s Avatar
johnno!
one more question, my ac bracket is definately diffrent, so I guess Im back to the threaded rod. could you tell me the length of that rod brace?
Thanks again
John
Old Mar 12, 2009 | 05:49 PM
ShadowC4's Avatar
ShadowC4
kinda a dumb question. what happens when you run a pump in reverse of what it should be doing. i want to remove my air pump but i don't want to mess up the engine.
Old Mar 12, 2009 | 06:05 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Default Air pump delete
Why don't you use an air pump delete bracket. That way you can even use the factory belt. Just an idea.
rk
Old Mar 12, 2009 | 07:49 PM
Aardwolf's Avatar
Aardwolf
Those air delete pulleys are expensive. This just costs $15 in a new belt, you'll make money selling the old parts.
My bracket is roughly 10.5" bolt center to bolt center. Probably 11.25" in total length. You can place the alternator across a large arc there.
Old Mar 13, 2009 | 01:14 AM
ultraviolet70's Avatar
ultraviolet70
Aardwolf, how do you set belt tension?
Old Mar 13, 2009 | 07:02 AM
johnno!'s Avatar
johnno!
thats what i needed, going to order an adjustable rod and the belt today. thanks again!
Old Mar 13, 2009 | 09:46 AM
Aardwolf's Avatar
Aardwolf
I set the belt tension by placing a bar between the alternator and brace then pulling. Just like the old days! I squeeze the belt and see that it compresses about a quarter inch each side.
Old Mar 13, 2009 | 11:00 AM
LKoncar's Avatar
LKoncar
Here's a good thread with the Heim rod in use
http://forums.corvetteforum.com/c4-t...te-pulley.html
To AIR pump delete question
