Clutch problems
Old Mar 12, 2009 | 01:53 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Clutch problems
1990 L98 Vert ZF6 165k miles
I've been having a tough time shifting lately. The trans will often not want to go into gear and when it does, it is very rough. When sitting at a light (pedal pressed) and shifting into first, the car will roll forward as it engages the gear.
To me, this sounds like a hydraulic problem. Any other ideas?
If that diagnosis makes sense, where can I find a new/rebuilt slave? The masters seem to be easy to find but none of the local parts guys can order the slave.
Old Mar 12, 2009 | 07:35 PM
Heckler45's Avatar
Heckler45
Sounds like what my 94 was doing when the slave was leaking. Have you checked the fluid in the master? I found a (new) reliable slave at Advance Auto Parts, it was under $200 and has been holding for about 1 year now.
-Dave
