Help Name This Part!?
Old Mar 13, 2009 | 01:31 PM
rickneworleansla's Avatar
rickneworleansla
Default Help Name This Part!?
I'm ordering an oil pan baffel overnight from summit and I'd like to get this replaced also. It broke while removing. It was on the passanger side of the intake with some hoses connected to it. I believe it may be part of the evap system. If so can I just delete it? I could not find it in my FSM. What is this called? Part number anyone?
Old Mar 13, 2009 | 01:36 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Its one of those GM mystery whatcha-ma-call-its!
Old Mar 13, 2009 | 01:58 PM
toptechx6's Avatar
toptechx6
Looks like the one way vacuum check valve for the A/C and cruise, should be PN 15733271
Old Mar 13, 2009 | 02:04 PM
jmrl98's Avatar
jmrl98
Hi Rick, can't name it, but I had to replace an elbow piece that connects to it, and I'm not at home to view my FSM (85). Mine looks a little different, but it does the same as yours. It helps to operate the temp control on your AC/heat, by vacuum I'm pretty sure. You most likely don't want to delete it, as it may mess up how your engine runs aside from messin' with your cold/hot inside the vehicle. If i'm wrong, someone has got ya covered, or I'll check back later when I'm at home...
Old Mar 13, 2009 | 02:06 PM
rickneworleansla
That looks like the one. Thanks!
Old Mar 13, 2009 | 02:09 PM
WVZR-1's Avatar
WVZR-1
This "whatcha-ma-call-it" is a GM# 10135692 or ACDelco 15-5421
Here's an ID for you: http://198.208.187.182/internet/View...Number=15-5421
Old Mar 13, 2009 | 02:12 PM
rickneworleansla
It looks like theres an old number and a new number.
Old #14056648
New #15733271
Old Mar 13, 2009 | 02:13 PM
WVZR-1's Avatar
WVZR-1
Here's yours: http://198.208.187.182/internet/View...umber=15-50568
Old Mar 13, 2009 | 02:17 PM
MikeC4's Avatar
MikeC4
this is a very common 2 port check valve that you can also get at Pep Boys or Autozone
To Help Name This Part!?
