copper colored particles in oil
Old Mar 13, 2009 | 01:35 PM
294's Avatar
294
Cruising
Default copper colored particles in oil
I have an Lt-4 and at my last oil change I noticed copper colored particles at the bottom of the oil change pan. There wasnt a lot but it does concern me. The engine is completely stock and I change oil every 3000 miles with mobil 1 synthetic and I use purelator oil filters. It still has plenty of oil pressure, 52psi at idle, and runs great with no noises. I live in the Phoenix area and use the 10w-40. It has 75,000 miles on it.
Do I have a bearing going or is this normal?
Any known issues with the LT-1/4 regarding this?
Old Mar 13, 2009 | 01:38 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
My guess would be bearing but it doesnt sound probable. Do you track the car at all?
Old Mar 13, 2009 | 01:44 PM
Ryan59's Avatar
Ryan59
Cam, rod & main bearings and valve guides. That's about all the internal parts that have brass in them.
Old Mar 13, 2009 | 01:49 PM
eguyett1985's Avatar
eguyett1985
You could verify what the material is by sending a sample to these guys:
http://www.blackstone-labs.com/
I have been using them for a few years now and send them a sample of the oil from my Powerstroke Diesel every other oil change. It's very reasonable and they send you back a very detailed analysis report.
Old Mar 13, 2009 | 02:58 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I have seen bearings go out but there were no particles in the oil or signs of prior failure. They were street driven cars but they were driven hard! I don't know about your car since I have no idea how you drive it or if it's raced. If you drive it normally and keep the oil changed, I don't see a reason as to why it could be failing? Install a magnetic drain plug. They are about 4 dollars. At your next oil change, look at the plug and see if the particles stick to it.
Old Mar 13, 2009 | 04:35 PM
steven mack's Avatar
steven mack
My vote is the bearings.I would drop the pan and check them.
Old Mar 13, 2009 | 04:43 PM
Black84's Avatar
Black84
Is the oil drain pan you use only used by you? I would cut open the oil filter that was just removed to see if any of this foreign matter is in the filter.
Old Mar 13, 2009 | 04:52 PM
M.J.L.'s Avatar
M.J.L.
Thanks. I just ordered two free sampling kits for my car. Oil and transmission fluid. Seems quite cheap and detailed.
Old Mar 13, 2009 | 08:44 PM
294's Avatar
294
Cruising
Thanks for all of the quick replies! It hasn't seen any track time. I actually don't drive it that hard. I made sure the oil pan was clean before I used it. I never thought about the valve guides. Are they more or less susceptible to wear when Roller rockers are used? If it is the valve guides would I be able to hear it or detect it in any way?
Old Mar 13, 2009 | 08:56 PM
JackDidley's Avatar
JackDidley
Take a look now. It may save some $$$$, to find a problem early.
Old Mar 13, 2009 | 09:40 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If the bearings are down to the copper, you have a detonation problem.
I too live in the Phoenix area, and drive my car in the summer about 4 days a week, and no copper colored anything.
I too have 52 PSI at idle.
Old Mar 14, 2009 | 01:15 AM
eguyett1985
You're welcome! I found them through one of the Powerstroke forums..lots of us guys use them and their results are quite thorough.
Old Mar 14, 2009 | 03:43 PM
294's Avatar
294
Cruising
I dont believe I have a detonation problem. The only time I here it knock is when it starts when it is warmed up. It makes about 2 knocks while starting. I assume that is the computer checking the timing or knock sensor. Is this correct?
If it is a connecting rod bearing and if I caught it early is it possible that there might not be any dammage to the crank shaft journal? Would I be able to just replace the bearing? I assumed if the bearing is bad then the journal would have to be resurfaced.
Old Mar 14, 2009 | 03:59 PM
M.J.L.'s Avatar
M.J.L.
If it's making a knock sound, it could be a bad lifter. If it makes a ticking sound, that could lead me to believe it's a bad exaust manifold gasket. Maybe it is the bearings but I know nothing about the materials they are made of or how the copper got in the oil. Our explorer had a bad lifter and my Corvette had a bad exaust manifold gasket.
To copper colored particles in oil
