SuperRam Gurus please check in
before tightening. But I'm wondering if any of you have come up with a "new and improved" method.
Also, if I end up tightening the screws from under the plenum, is it better to have 12pt. screws, or others? I'm open to suggestions, thanks guys.
.I called Accel when I first got my SR and talked to a rep that spent most of his time installing the SR on various cars and testing. He suggested throwing out the screws provided and going with studs and star nuts. That is what I did. I think if I was using the original screws provided.....I would still be trying to get them started
Honestly, you don't have to do it that way, you can use your current fasteners. The "only" difficulty people have with the Superram is the inside plenum belly fasteners. There a couple of keys that actually make these fairly easy to install...... first is, do not torque down the runners yet.... leave them just a hair loose so you can wiggle them 1/16" as needed.
Start a couple of the outside plenum belly bolts, this should automatically line-up the others. I think when they do not line-up for people, was because the original runners have been seperated from the original plenum it came with. In any regards, to do the inside fasteners, first unplug the injectors and put a couple of papertowels in each runner from the top (protect an accidently drop of something down the runner) then, slot the ends as you already know and then the only trick is to "cradle" the fastener with a socket wrench and take it to the hole, apply a little upwards pressure and bring it up from the top with a screwdriver while you cradle it below...... get it started and 2 or 3 full revolutions into the thread and then go to the next one. Thats it.... after you have them all started, bring them in, but don't torque, instead torque the runners, then go back and torque the plenum belly bolts. Pull the paper towels and put on the lid reconnect the injectors.
I've installed countless superrams..... I guess the first one for me was a bear.... but after that, just not a big deal, I can do the whole manifold in about an hour...... you can too.
good luck !
good luck !
I know that Agent 86 reversed this process and has the bolts INSIDE the plenum. But he also drilled the studs so that when the bolts are threaded onto the studs there is a safety wire threaded through the holes in the studs to prevent the bolts from falling into the runners.....and your engine
...that is a BAD THING.I am afraid that I would not trust silicone or threadlock to keep the nuts from backing off. The heat cycles of the engine do strange things to fasteners over time.
http://forums.corvetteforum.com/c4-t...ghlight=auveco
1" Auveco 9667 studs may work even better but I haven't tried them
Here's a source for the studs:
http://dixie.hypermart.net/store/page19-ss2.html
.Well I used a magnet and it sucks the bolts up in the whole, then I just turned them up in, and snug with a box end wrench or socket on some.
It's harder than a miniram, but not anything other than putting bolts in holes. The problem is leaks not assembly.
FWIW I have not installed a Mini but I think it is very straight forward. If you can assemble things, you can do the SR even with stock bolts.
I've done minor mods like slotting the bolts and I use studs on the inner bolts. I installed it for the third time this weekend. Took about an hour, mostly because I was paying so much attention to sealing gaskets. Seal the gaskets right the first time. I used a little RTV on the lower runner gaskets and white lithium grease on the upper gaskets. No leaks!
Also i had a plug in my plenum where the MAT sensor went so i just left it and i think im goin to relocate it into my intake piping, is this an ok idea?
Lastly i am running a fuel presure gauge off the fuel rail and with that and the SR i can tell trying to get to the AFPR bolt on top is goin to be a Pain in the ACE....anyone else have this problem?
i cant wait to get it finished and maybe take it for a drive tomorrow!
