FinallY! Drivers Side Wires Off! But . . . . .?
Old Mar 14, 2009 | 04:43 PM
Donne Trav's Avatar
Donne Trav
Default FinallY! Drivers Side Wires Off! But . . . . .?
After all the struggle and another trip to an auto parts place for a tool
that I thought would help (an 11" set of needle nose pliers) with 2 of the 4 having 2 different angles at the end. Wow, I knew one of these was going to work. The first 2 from the bottom — from underneath the car — were easy enough. Still working from under the vehicle, I was unabe to get a good grip with either one of the 11" needle noses on the next 2. I'm starting to get really "salty" now. Then, suddenly I yanked on the next wire, which was being held together with that "core" piece that is in the center of these wires. "Pop!. Wire/boot off! Same on the last one, "pop"—off! But, in my tantrum, I realized I had not marked either end of the old wires. So now I'll be seeking info on matching the new wires from the Opti to the to the plugs. Hopefully, that info will be in the "94 GM Service Manuals" I recently purchased on E-bay. Now, to get them to "Pop" on as easily. All of you were a BIG help as usual. THANKS
Old Mar 14, 2009 | 05:14 PM
MikeC4's Avatar
MikeC4
don't forget to put dielectric grease inside the boots, all 16 of them..
Old Mar 14, 2009 | 05:19 PM
pianoguy's Avatar
pianoguy
And burp the air out of the opti boots before you snug them down.
Old Mar 14, 2009 | 07:55 PM
Donne Trav's Avatar
Donne Trav
Default Huh?! "Burping the "Boots" baby? Naaaw
I could barely "burp" my infant daughter over 40 years ago. So, how is this done? Never heard of 'burping" anything on a vehicle before. You're
being a "funny bunny" right?
Old Mar 14, 2009 | 08:00 PM
Donne Trav's Avatar
Donne Trav
Thanks Mike, very nice diagram. Did you see the "reply" — Don't forget
to "burp" the boots — all 16 of them"? What does this mean? Also, what
is the "dielectric grease for? THANKYOU
Old Mar 15, 2009 | 12:31 AM
383vett's Avatar
383vett
I think he was kidding about burping spark plug boots. I've been into cars for years and have never heard of this. The dielectric grease lubricates the boot to make it easier to take the boot on and off and also prevents the spark from escaping between the boot and plug.
To FinallY! Drivers Side Wires Off! But . . . . .?
