Rust inside the Intake Manifold!
Old Jan 27, 2002 | 10:08 PM
mn_vette's Avatar
mn_vette
Default Rust inside the Intake Manifold!
I recently pulled off my intake manifold for a cam change and I shined a light in it just out of curiosity and is appeard to be rusted all over the inside. I then checked my throttle body and the back of the fins (I have no clue what they are called, the things that open and close the tb) were also rusted. Does anyone know if this is normal, if now what causes it and how to fix it? Thanks guys.
Old Jan 27, 2002 | 10:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Rust inside the Intake Manifold! (mn_vette)
Do the TB coolant bypass the gasket below the TB may be leaking.
The intake manifold rust may be due to coolant leaning inside the base.
pablocruise's Avatar
pablocruise
The round throttle blades(2 of them)? Rust/oxidation isn't normal. A coating of oily residue would be quite normal for these motors. Try seeing the gaskets in the throttle body(3 of them). What condition? Bypass the throttlebody coolant lines.
Old Jan 27, 2002 | 10:24 PM
mn_vette's Avatar
mn_vette
Default Re: Rust inside the Intake Manifold! (89 Paul in cal)
ok, a tb bypass, not a problem, but wouldn't that have done something really bad to the engine if it was sending antifreeze through the engine? It did cause the entire inside of the intake to rust, top, bottom, sides, all of the surface on the inside is covered in rust. I wouldn't think a coolant leak would do that, but I could be wrong.
Old Jan 28, 2002 | 12:47 AM
skidmark's Avatar
skidmark
Have you modded the air intake? Some aftermarket systems can allow rain to enter the intake.
Old Jan 28, 2002 | 02:31 AM
Kevin 88's Avatar
Kevin 88
Default Re: Rust inside the Intake Manifold! (skidmark)
Since the intake is aluminum water entering it won't create rust. Must be coolant that is carrying rust from the block.
Old Jan 28, 2002 | 09:43 AM
mn_vette's Avatar
mn_vette
I've opened up the air box, and that's it, but that was only two months ago, and the car has been hibernating for atleast half of that time.
To Rust inside the Intake Manifold!
