Rear differential # spec.
Old Mar 15, 2009 | 06:23 PM
twin540's Avatar
twin540
Default Rear differential # spec.
Under my differential number spec. I read 2.59 44-17.. Does that mean I have 2.59 gears? I always thought i had 307 gears , can somebody shime in.. Thanks..
Old Mar 15, 2009 | 08:19 PM
Jagdpanzer's Avatar
Jagdpanzer
44-17 is the number of gear teeth of the R&P set the case was originaly equiped with. 2.59 is the resulting reduction ratio.
Old Mar 15, 2009 | 09:36 PM
WVZR-1's Avatar
WVZR-1
I would have guessed you would "notice" a 2.59 just by the "driveability" of it. An A4 with a 3.07 should feel fairly responsive! Do you know if it has been changed by a PO?
Perhaps you should do a couple things. With a GPS or "mile-markers" confirm the accuracy of the "odometer". If the odometer checks then you might rely on the GPS to do a confirmation of the "speedometer" for accuracy. I've used a Delorme GPS that did MPH in tenths "reliably"! It's easier to do the two tests "separately".
Now assuming your "tach" is correct you can confirm the speed at a specific RPM and calculate with in reason the axle ratio doing some math.
Here's the math explained and a simple calculator for ease of use. NOTE that the "tire dimension" used is "loaded radius"! You will need to measure that "accurately". There are other calculators that do similar but some/most don't rely on a "loaded radius" dimension. Speedometer calibrations from manufacturers use "loaded radius" for correction. I would do the comparisons in 3d gear which is 1:1.
I like this one because the "math is explained", you can do the math yourself if you've doubts!!
http://wahiduddin.net/calc/calc_speed_rpm.htm
To Rear differential # spec.
