Adjustable Fuel Pressure Regulator
Old Mar 15, 2009 | 11:39 PM
cumbercr's Avatar
cumbercr
Default Adjustable Fuel Pressure Regulator
Yesterday, I installed an adjustable fuel pressure regulator from TPiS. My 85 has a rebuilt 350 that was bored .060 over, 10:1 compression, a Competition mild cam and Corsa exhaust. I have replaced the injectors, fuel pump, ignition, etc. but I have always had a significant ping. I thought I would have to replace the cast iron heads to get rid of it.
I increased fuel pressure from 39 psi to 47 psi. The ping is gone. The added benefit is more power. I hoped the increased fuel pressure would promote a more efficient burn and the O2 sensor would see a lean condition and increase the injector pulse. I never expected the increase in power I feel. Has anyone else had a similar finding? If what I'm felling in power is true, this is some pretty cheap horsepower ($69).
Old Mar 15, 2009 | 11:59 PM
Klondike's Avatar
Klondike
Haven't done it on the Vette yet, but I replaced the fuel pump on my Mustang 5.0 with a higher capacity one and also added an adjustable regulator. I didn't up the pressure but only about 4lb. but I could feel a BIG difference in the mid range pull of the motor. I think the stock pumps in most cars are right at the edge of their capacity when just normal driving. Trying to get much performance from them, specially after a few years on the road, is more than they can supply, and I think the car's performance suffers from "tired pump syndrome". The Vette's day is comming and it will get a fresh pump and FPR and I bet it will wake up too!
Old Mar 16, 2009 | 12:32 AM
383vett's Avatar
383vett
You might need a custom tune due to the different cam. Are you able to monitor your 02 sensor or block learn numbers?
Old Mar 16, 2009 | 02:41 AM
lite blue's Avatar
lite blue
St. Jude Donor '12
'85s benefit from an AFPR like no other year. The factory setting is really low, and the increased pressure just helps the injectors atomize better. I first put a TPIS AFPR on an '85 Trans Am I had with the LB9 ( TPI 305), and later put one on an '85 Vette. They both responded really well.
Old Mar 16, 2009 | 09:55 AM
cumbercr's Avatar
cumbercr
Originally Posted by 383vett
You might need a custom tune due to the different cam. Are you able to monitor your 92 sensor or block learn numbers?
I don't have any way to monitor the O2. I considered having a new chip burned. But several people told me the 85 computer should take care of the mods I have.
Old Mar 16, 2009 | 10:12 AM
jmrl98's Avatar
jmrl98
From my lurking in the scan/tune section, I've found the 85 computer to be on the slow side, and not very informative. For example, on my autoxray I can't get some real time data the other L98 computers give. When I called autoxray, they said it was my 85 computer setup, not the autoxray scanner. As long as I get O2 voltage variation, I figure I'm good to go with lean/rich conditions. You need a chip tune fo sho with a cam swap to get the most out of it. Also, watch that FPR if indeed you used your stock diaphram - my diaphram gave out and I had gas way up the intake.
Old Mar 16, 2009 | 10:15 AM
Demonic85's Avatar
Demonic85
I'm sorry but 47 psi is just too high for an '85 even with a few mods. I would hook it up to a scan tool and see whats really going on. I have a feeling the added fuel is masking something.
The highest i've ever adjusted mine to was 55 psi (by accident) and it was spewing fuel out the tailpipes. I currently have mine set at 36.
Old Mar 16, 2009 | 10:25 AM
jmrl98's Avatar
jmrl98
Ya know, I was going to mention something about what demonic is touching on. When I bumped my FP up to 51, it would cut out at WOT for a millisecond, then catch and haul *****. After thinking it was a timing issue & messing with that, I lowered the FP to 47 and it stopped the cut out. But it smelled way rich throught the exhaust, and what my O2 sensor was telling me when scanned. It is now at 44.
Old Mar 16, 2009 | 11:19 AM
Kool88vette's Avatar
Kool88vette
I see you're from California. I failed a visual because of an adjustable fuel pressure regulator. The emissions were good but I still failed. I had to remove the AFPR and reinstall the stock regulator.
I think you should get a custom tune.
Old Mar 16, 2009 | 07:26 PM
cumbercr's Avatar
cumbercr
The AFPR I bought from TPiS has a CARB number so it is CA legal.
Old Mar 16, 2009 | 07:35 PM
cumbercr's Avatar
cumbercr
I bought the AFPR from TPiS. They recommended 47 psi with the vacuum hose disconnected. The stock pressure was 39. With the vacuum connected, it's running 39 psi at idle. I'm not smelling any rich exhaust.
To Adjustable Fuel Pressure Regulator
