Wiring problem...help me Please!!
Old Jan 28, 2002 | 04:05 AM
colotocali's Avatar
colotocali
Default Wiring problem...help me Please!!
It's bad guys....real bad! I tore apart my dashboard ( in a '91) the other night to try to fix the SYS light that kept flashing. Couldn't fix it so I put it back together. Now, when I turn on the lights the dashboard lights don't come on. It is almost completly dark in my car at night when I drive. I can still read the MPH in the LED but the dimmer control for the lights doesn't work at all. I just move it up and down but nothing happens at all. I did notice the other night when I auto-started it ( I have an alarm with the auto-start on it..a viper) the dashboard lights came on until I stepped on the brake. The brake is the auto kill for the alarm,l but if I start it normally the lights won't even blink. Now I noticed (or accually someone pointed it out while I was driving) that I don't have any tail lights! I have brake lights but no tail lights...what the heck?
Old Jan 28, 2002 | 04:53 AM
Shayne's Avatar
Shayne
Default Re: Wiring problem...help me Please!! (colotocali)
I think the most common reply to this question is going to be to "take it apart and reassemble it slowely" You might have crimped a ground or are shorting a line somewhere during the reassembly.....I did not reassemble my door right when I took it apart...when I rolled the window down then up...it pulled the wires out of the motor.....easy thing to over look....Good luck
Old Jan 28, 2002 | 05:02 AM
pablocruise's Avatar
pablocruise
This is dumb on my part, but how's that fuse?
Old Jan 28, 2002 | 10:20 AM
David-F's Avatar
David-F
It does sound like a blown tail lamp fuse you need to check the fuses first. Also what code were you getting in the CCM that made you remove the dash in the first place?
David Fulcher
Old Jan 28, 2002 | 07:20 PM
colotocali's Avatar
colotocali
Default Re: Wiring problem...help me Please!! (David-F)
No code David...just trying to fix the SYS light after putting in an after-market radio. By the way...the fuse is fine :D thanks
To Wiring problem...help me Please!!
