Frisbee going back on
Old Jan 28, 2002 | 11:30 AM
jwade91's Avatar
jwade91
Default Frisbee going back on
I finally took this thing off last week when I changed the belt, but I think it has a purpose. At low RPMs my A/C is squeeling ... just figured that out today in traffic coming into work ... It must create some load or force that helps prevent that. Am I wrong?
Another thought -- Can the spring in the belt tensioner wear out? Mine seems too loose. I can just pull on the belt and move the tensioner fairly easily? Maybe that's it ... ???
Old Jan 28, 2002 | 11:33 AM
h rocks's Avatar
h rocks
Default Re: Frisbee going back on (jwade91)
Bingo! Yes, the tensioner can and does lose some of it's strength. I was surprised at just how much when I replaced mine last year. ('90) BTW, make sure you change your belt every year or two even if you think it "looks" good. They go through a lot, and they get baked under the hood.
[Modified by h rocks, 10:35 AM 1/28/2002]
Old Jan 28, 2002 | 11:44 AM
jwade91's Avatar
jwade91
Default Re: Frisbee going back on (h rocks)
Yeah, belt looked fine, just stretched. It was about a year old or so.
The power steering was acting up, and JASONL recommended checking the belt. Seemed to fix the problem. But that tensioner must have been part of the problem too.
I noticed on the computer screen at the parts desck the other night at AUTO ZONE that a belt tensioner was not available for my car ... Do I need to go through a GM parts dealer, like The Last Detail??
Thanks.
Old Jan 28, 2002 | 07:26 PM
KNCRSR5R's Avatar
KNCRSR5R
I took mine off and there is NO slippage or squeal!!! But I do have exactly 100,000 miles less than you!!
That Rocks man....I hope at 212,000 thats all the probs I have!!
:yesnod: :cheers:
Old Jan 28, 2002 | 08:47 PM
Vic'89's Avatar
Vic'89
Mine is off and I don't have any problems.
Also, I don't use the A/C much.
Vic
Old Jan 28, 2002 | 10:03 PM
89BP's Avatar
89BP
I could be wrong, but didn't they take them off starting in 90?
Jeff
Old Jan 28, 2002 | 10:58 PM
torchred96's Avatar
torchred96
Default Re: Frisbee going back on (89BP)
My 90 has the frisbee too and I looked at a 91 today and it also had it.
sam
Old Jan 29, 2002 | 10:34 AM
art91's Avatar
art91
Jeff
Nope. I just took mine off my 91 this past saturday. :) I think the weight and style changed in 90, though. Mine didn't weigh that much.
To Frisbee going back on
