88 C4 auto transmission shifting problem
Old Mar 18, 2009 | 05:57 PM
superspeeder's Avatar
superspeeder
Default 88 C4 auto transmission shifting problem
Hi guys!
I have a problem with auto tranny shifting. When I hit the kickdown and revs go up the tranny doesn't shift at the right time(at least I think so). It accelerates good but it doesn't shift before reaching the rev limiter and staying there about 1-2 seconds and then it shifts and same thing with next gear. Should it be shifting before the rev limiter?
I would make video but my engine is apart right now.
Maybe someone have any idea whats wrong with my car?
Old Mar 19, 2009 | 12:46 AM
jesredvette's Avatar
jesredvette
I have the same issue with my 88; hopefully someone can shed some light on this.
Old Mar 19, 2009 | 05:37 AM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Have you tried adjusting TV cable at throttle body?
Adjustment is fairly simple, check any manual or look here in ech tips
Old Mar 19, 2009 | 11:45 AM
JOHN89's Avatar
JOHN89
Originally Posted by superspeeder
Hi guys!
What year is your car/transmission?
Old Mar 19, 2009 | 11:48 AM
JOHN89's Avatar
JOHN89
What RPM is this occurring at. I don't believe your 88 has a rev limiter. At least not from the factory. The governor in the transmission determines shift points at wot. If it is shifting higher than 4500 rpm, the governor has been modified or is damaged.
It's under the round black cap on the side of the transmission.
John
Old Mar 19, 2009 | 02:02 PM
superspeeder
1988 year vette and TH700R4 transmission. It's shifting at about 5000+rpm with when I hit the kickdown. When I'm just cruising it's shifting normally.
To 88 C4 auto transmission shifting problem
