85 engine specs please
Old Mar 18, 2009 | 09:55 PM
motodog's Avatar
motodog
Default 85 engine specs please
does anyone know what the cam specs, comp ratio, piston material, valve size, chamber size, ect, a 85 l98 with.
Old Mar 18, 2009 | 10:25 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
I am pretty sure your cam specs are 202/206 0.50, forged pistons because they changed that in 86. 84 and 85 both had forged pistons but I don't know why they changed it in the later years. Hopefully someone with more knowledge will chime in. If I made a mistake, please let me know someone.
Edit: Does anyone have any information as to why GM changed from forged pistons after 85?
Old Mar 18, 2009 | 10:53 PM
rodj's Avatar
rodj
202/206 @ .050", 403/415 lsa 114.5.
1.94 / 1.50 Valves
Cast heads prob same as F-body L98 iron heads at 64cc
Old Mar 19, 2009 | 03:28 AM
khhammer's Avatar
khhammer
The 85 L98 iron heads were 76cc
Old Mar 19, 2009 | 09:31 AM
Demonic85's Avatar
Demonic85
230 HP / 330 ft. lbs torque
Cast iron engine block with 2 bolt main caps
4.00 x 3.48 (bore x stroke), 350 ci.
forged TRW pistons
cast crank and rods
9.0:1 compression ratio
6 degrees BTDC @ 650 rpm
Cam
Duration @ 0.050 202/206
Lift with 1.5 R 403/415
Lobe Seperation 114.5
Cast Iron cylinder heads
1.94 intake/1.50 exhaust
76cc combustion chamber
160-165cc intake runners
Bosch TPI
24 lb/hr Rochester fuel injectors
30 psi fuel pressure regulator
50 psi / 24 gph in tank fuel pump
ECM 1226870
Old Mar 19, 2009 | 12:34 PM
motodog's Avatar
motodog
thanks guys. its nice to know whats in your car
To 85 engine specs please
