Removing Plenum - How to get to Torx Bolts
Old Mar 19, 2009 | 09:27 PM
davlabo's Avatar
davlabo
Default Removing Plenum - How to get to Torx Bolts
Ok. I decided to be brave and tackle this project of changing the fuel injectors on my 1989 Corvette (thanks Jon Banner for great prices and service!). How the heck do I get to the bottom torx bolts on the runners? Is there a tool I can buy to make it easier getting in there?
Old Mar 19, 2009 | 09:31 PM
John A. Marker's Avatar
John A. Marker
You have to remove the plenum first. Then a long 3/8" extension to get to the bolts with a torx that fits the 3/8" extension. There are also bolts on the inside of the runners. BE SURE TO LABEL each bolt as you pull them off......they are different sizes
Also be prepared to fashon some form of plug for your fuel lines....even with the pressure released the lines will leak. You don't want fuel spilling and flowing for any length of time.
Old Mar 19, 2009 | 10:13 PM
davlabo's Avatar
davlabo
Thanks for the advice. I got the plenum out and labeled the bolts. Now, do I really need to remove the runners to replace the injectors or can I get to the fuel rails while leaving the runners intact?
Old Mar 19, 2009 | 11:05 PM
cumbercr's Avatar
cumbercr
It's easier just to remove the runners. There's one torx bolt on the passenger side near the front that gets removed from the back side.
Old Mar 19, 2009 | 11:08 PM
ride250s's Avatar
ride250s
Just to throw this in, be careful when putting the plenum back on. I almost stripped a few holes out because it was really tough lining up everything, it was a tight fit, so just take your time
Old Mar 20, 2009 | 12:26 AM
Muffin's Avatar
Muffin
Actually there are two which must be removed from the back side.
Old Mar 20, 2009 | 01:04 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Yes. You have to remove the EGR valve and collapse the fuel rail before removal though. It won't come out w/o doing that.
To collapse the fuel rail, remove the two crossover tubes.
Old Mar 20, 2009 | 09:51 AM
mudslide's Avatar
mudslide
I hope your injectors were tested for flow and electrical. I put in a new set on my 90 and had one bad one and had to go through the hole thing again. But its easier the second time around lol
Old Mar 20, 2009 | 09:56 AM
Sam Lam's Avatar
Sam Lam
You do not have to remove the runners in order to have access to the injectors. I agree that removing the runners will allow easier access to the injectors, but the injectors can be removed by leaving the runners attached to the intake manifold. I have done this many times.
Old Mar 20, 2009 | 10:03 AM
cumbercr's Avatar
cumbercr
This is another reason to remove the runners. If you leave the passenger side runner loose when reassembling, its easier to get the plenum on and you don't damage gaskets. Make sure you check for fuel leaks before reassembling the runners and plenum. Oh and don't forget the connector on the bottom of the plenum. I made that mistake. Felt like an idiot.
Old Jul 30, 2010 | 08:33 AM
krazy1's Avatar
krazy1
[QUOTE=John A. Marker;1569367330] BE SURE TO LABEL each bolt as you pull them off......they are different sizes
I had my bolts in a magnetic tray that the gremlins kicked to the floor. I have 2 bolts that are 1/4 in. longer than the plenum bolts and am not sure which holes that they go in. I don't want to have a vacuum leak when i put it back together. Any ideas?
Old Jul 30, 2010 | 10:56 AM
JAKE's Avatar
JAKE
[QUOTE=krazy1;1574855428]
Stick something, like a cut off piece olf coat hangar, into the bolt holes and see how deep they are before bottoming out. That'll tell you.
I've removed the fuel rails with the injectors still attached (86 Vette) to pressurize the fuel system to see if any injector was leaking. Too late in your case though.
No need to make this little task more complicated then need be is how I approached it.
Jake
Old Jul 30, 2010 | 12:03 PM
ejscarfo's Avatar
ejscarfo
The outboard bottom bolts on the runners I got using one of 2 tools. The first one being a "T" whatever size socket on a 3/8 drive. The length of torx bit was double what you would normally find, got them from Harbor Freight, made easy to remove and tighten the outboard bolts. The second tool I used was just for reinstallation to get the bolts started, it was screwdriver type torx tool. The 2 inside bolts weren't easy, but I fashioned a quick tool to do it. I took a torx bit from a bit driver set, inserted it into a 1/4 drive socket (I can't remember the size) and used a long 1/4 extension with a universal. It lays low, clears everything and makes it easy to remove those 2 bolts.
You can remove the injectors without actually removing the runners. Removal of the plenum usually gives you the room. However, mine wouldn't come out without loosening the runners. At that point it was easier to remove the runners as well and send both plenum and runners to get cleaned and bead blasted.
To Removing Plenum - How to get to Torx Bolts
