Slippage
Old Mar 20, 2009 | 10:47 AM
Chapindad's Avatar
Chapindad
Default Slippage
Okay here we go again. I got my fuel pump fixed and now I am seeing severe slippage in the transmission. I checked the fluid level and it is perfect. Right now it will go into drive but not reverse. What kinda of damage and repair am I looking at?
Old Mar 21, 2009 | 06:57 AM
Pete K's Avatar
Pete K
If the trans is slipping, and the fluid level is correct, you may have a filter that has cracked, blocked, or leaking at the o-ring. The fact that the car moves in 1 direction, but not the other makes that unlikely.
Double check the linkage adjustment at the drivers side of the trans, near the pan rail.
If everything checks out, it is rebuild time. $1k-3K depending on how you rebuild it, what type of converter you buy, and what local labor rates are.
In my area $1500-$1800 installed is the going rate for a vette rebuild.
Old Mar 22, 2009 | 08:03 PM
Chapindad's Avatar
Chapindad
You are going to make me cry. I just can't catch a break.
Old Mar 22, 2009 | 08:54 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
you can buy a good serviceable one at a wrecking yard or a forum member for about $500, but not this forum member. I don't have any extra transmissions.
Old Mar 22, 2009 | 08:55 PM
Pete K's Avatar
Pete K
Too bad I was not still in the biz. Garage is cleaned out though
To Slippage
