onepantera
Old Mar 20, 2009 | 03:07 PM
onepantera's Avatar
onepantera
2nd Gear
Default onepantera
I am new to this site and also am new to the Vette world. i was told this was the place to go. I have a 95 C4 Vette automatic, bone stock. When it is cold it runs great wheni it warms up it runs like poop. I came to realize the previous owner was eating up O2 sensors so he knocked out one of his Catalytic converters on the driver side. It spits and sputters and the check engine light comes on. I was told to knock the other converter off and run straight pipes and then put on O2 simulators on. Will this cure my problem? If so my next step is performance, I just went thru a divorce and would like to add cheap horse power for now. I cant find anybody that has an aftermarket air intake system. Can someone help me out. Thanx Brent
Old Mar 20, 2009 | 03:19 PM
STL94LT1's Avatar
STL94LT1
No need for o2 simulators on your 95. It only has one post cat o2 and it can be eliminated without a problem.
Old Mar 20, 2009 | 04:25 PM
KoKane's Avatar
KoKane
I run straight pipes on my 95. No cats. I only use the the 2 precat o2 sensors. Just eliminated the one post cat o2 sensor. Runs fine with no check engine light.
Old Mar 20, 2009 | 05:17 PM
pologreen1's Avatar
pologreen1
welcome
Old Mar 20, 2009 | 06:14 PM
MikeC4's Avatar
MikeC4
The first thing you need to do is check for error codes. This will tell you if you have an O2 sensor problem or whatever:
Getting your error code is a simple "DYI in the driveway" job:
http://www.corvettebuyers.com/c4vettes/codes.htm
Running good when cold ==> "open" Loop ==> O2 sensors ignored by PCM
Running like poop when hot ==> "closed" Loop ==> O2 sensor information used by PCM to calculate/correct AFR
Old Mar 21, 2009 | 02:32 PM
onepantera's Avatar
onepantera
2nd Gear
Default Hello
Thanx everybody for the advice on my 95 Vette. Again I am ignorant when it comes to this stuff, but after I pull out the post O2 sensor and run straight pipes, how do I clear the codes? Unhook the battery and hook it back up? Thanx Im doing all this on Monday at my buddies shop so if you guys can answer before then it will help. Thanx again Brent
Old Mar 21, 2009 | 03:57 PM
j-wireman's Avatar
j-wireman
I believe so. On a '90, just remove the negative ( - ) terminal and leave off for ten minutes. Put back on. Scan for codes, again. A '95 could be different, but I think they're all close to being the same.
Oh, yeah. You have definitely come to right place.
One more thing. Buy a Factory Service Manual. Everything about your car is in there. I bought one. I love it.
Mike
'90 'vert
Old Mar 21, 2009 | 04:00 PM
MikeC4's Avatar
MikeC4
The simplest way to clear your stored error code is to disconnect the negative battery terminal for about 30 seconds.
Abetter way is to use a shorting wire on your ALDL connector and following these instructions :
On a 94/95 you can check the codes with a paper clip as follows:
You short pin "12" to pin "4" and turn the ignition switch to "On" without starting the engine.
The speedometer will display any codes using the same protocol as the 1990-1993 model but there are some changes in the designation for the modules plus additional modules are added:
Module "1" is still the CCM module.
Module "4" is now called the PCM module (Powertrain Control Module) because automatic transmission computer control was added to Engine Control Module in 1994.
Module 7 (on the 1996 model only) is the RTD module. (This is the Real Time Dampening module which replaced the Selective Ride Control module in 1996).
Module 9 is the ABS/ASR module number from 1994 through 1996.
Finally, Module "A", the DERM (Dynamic Energy Control Module --- (the air bag control module) will be requested to show any codes.
Just like the 1990-1993 display, you read the codes on the speedometer (big) and read the module number on the trip odometer (small).
A series of dashed lines for instance “ - - -“ indicates no more stored codes for that module.
A code showing as “C12” for the CCM module (module #1) means no codes are stored. So C12 is a good thing to see.
Again, you can cause the codes to repeat by turning the ignition off for five seconds and then back on.
Turn the ignition off and remove the short to restore normal operation.
To clear the codes,
1. With ignition "off" ground terminal #12 of the DLC (use bent paper clip to connect pin 4 to pin 12)
2. Turn ignition "on".
3. Press trip/odo button on the DIC until 1.7 appears in the trip
monitor area of the instrument cluster.
4. Press eng/met button on the DIC & hold until "---" appears in the
speedometer area of the cluster, this will clear CCM DTC'S.
To clear PCM/ECM codes do the following:
1. Press the trip reset button on the DIC until the desired system is displayed. In this case it will be 4.0.
2. Press trip/odo button on the DIC until the desired diagnostic mode(4.7) is displayed on the trip monitor area of the cluster.
3. Press & hold the eng/met button on the DIC until "---" is
displayed in the speedometer area of the cluster, this will clear PCM codes.
To clear ABS/ASR codes do the following:
Same as above but you’re looking for “9.7” on the trip odo
And here are the codes
1994-1995: Diagnostic Trouble Codes
DTC #11: Malfunction Indicator Lamp Circuit.
DTC #13: Bank #1 Heated Oxygen Sensor #1 Circuit:
DTC #14: Engine Coolant Temperature Sensor Circuit Voltage Low.
DTC #15: Engine Coolant Temperature Sensor Circuit Voltage High.
DTC #16: Distributor Ignition System Low Pulse.
DTC #18: Injector Circuit.
DTC #21: Throttle Position Sensor Circuit Voltage High.
DTC #22: Throttle Position Sensor Circuit Voltage Low.
DTC #23: Intake Temperature Sensor Circuit Voltage High.
DTC #24: Vehicle Speed Sensor Circuit.
DTC #25: Intake Air Temperature Sensor Circuit Voltage Low.
DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
DTC #27: EGR Vacuum Control Signal Solenoid Valve Circuit.
DTC #28: Transmission Range Pressure Switch Assembly Fault.
DTC #29: Secondary Air Injection Pump Circuit.
DTC #32: Exhaust Gas Recalculation.
DTC #33: Manifold Absolute Pressure Sensor Circuit High.
DTC #34: Manifold Absolute Pressure Sensor Circuit Low.
DTC #36: Distributor Ignition System High Pulse.
DTC #37: Brake Switch Stuck On.
DTC #38: Brake Switch Stuck Off.
DTC #41: Ignition Control Circuit Open.
DTC #42: Ignition Control Circuit Shorted.
DTC #43: Knock Sensor Circuit.
DTC #44: Bank 1 LF Heated Oxygen Sensor #1 Circuit Lean.
DTC #45: Bank 1 LF Heated Oxygen Sensor #1 Circuit Rich.
DTC #47: Knock Sensor Circuit Or Module Missing.
DTC #48: Mass Air Flow Sensor Circuit.
DTC #50: System Voltage Low.
DTC #51: EPROM Programming Error.
DTC #52: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #53: System Voltage Low.
DTC #55: Fuel Lean Monitor.
DTC #58: Transmission Fluid Temperature Sensor Circuit Low.
DTC #59: Transmission Fluid Temperature Sensor Circuit High.
DTC #62: Engine Oil Temperature Sensor Circuit Voltage Low.
DTC #63: Bank 2 RF Heated Oxygen Sensor #1 Circuit Open.
DTC #64: Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
DTC #65: Bank 2 RF Heated Oxygen Sensor #1 Circuit Rich.
DTC #66: A/C Refrigerant Pressure Sensor Circuit Open.
DTC #67: A/C Pressure Sensor Circuit Sensor or A/C Clutch.
DTC #68: A/C Relay Circuit.
DTC #69: A /C Clutch Circuit.
DTC #70: A/C Clutch Relay Driver Circuit.
DTC #72: Vehicle Speed Sensor Loss.
DTC #73: Pressure Control Solenoid Circuit Current Error.
DTC #74: Traction Control System Circuit Low.
DTC #75: Transmission System Voltage Low
DTC #77: Primary Cooling Fan Relay Control Circuit.
DTC #78: Secondary Cooling Fan Relay Control Circuit.
DTC #79: Transmission Fluid Overtemp.
DTC #80: Transmission Component Slipping.
DTC #81: Transmission 2-3 Shift Solenoid Circuit.
DTC #82: Transmission 1-2 Shift Solenoid Circuit.
DTC #83: Torque Converter Solenoid Voltage High.
DTC #84: 3-2 Control Solenoid Circuit.(Auto Only).
DTC #84: 2nd And 3rd Gear Blockout Relay Control Circuit.
DTC #85: Transmission TCC Stock On.
DTC #90: Transmission TCC Solenoid Circuit.
DTC #91: One To Four Upshift Lamp(Manual Only).
DTC #97: VSS Output Circuit.
DTC #98: Tachometer Output Signal Voltage Wrong.
To onepantera
