My 84 Vette Check Engine need help
Old Mar 20, 2009 | 04:48 PM
djirok's Avatar
djirok
Default My 84 Vette Check Engine need help
Hello Everyone I am new to the vette forums, but I purchased a 84 vette.. Il post up pics as soon as I find my camara cable..Anyways. THe check engine light comes on somethimes. It idles normal, I set the timing to 6 BTDC, and when Im driving around, and come to a stop sign, the vette will suddenly start idling higher, and the check engine light will come on. So far I changed the O2 Sensor, and thats about it.. Any ideas what it might be? OH yea plus my friend put a snap on scanner, and Code 24 and 44 came on.. Code 24 said something about no speed sensor input, and code 44 i dont know what it is..
thanks!!
Old Mar 22, 2009 | 12:25 AM
qws's Avatar
qws
Code 24- fuel injection Vehicle speed sensor (VSS)
according to the FSM it says disregard if set when drive wheels are not moving.
Code 44- Fuel injection lean exhaust, its possible that a code 33 or 34 could set this code. Are you sure that 24 isn't a 34?
Code 33 map sensor signal voltage to high
Code 34 is a map sensor to low
Old Mar 22, 2009 | 02:28 AM
djirok's Avatar
djirok
U are rite on all the info you gave me. It says the exact same thing here now that im reading the printouts he gave me.. Code 44 is a fuel injection lean exhaust indication.. He said maybe also my IAC are bad? Hes explanation is because alot of air is going in. When it comes to sensor and parts like that I really am lost. Another thing, I have noticed when I am driving the vette, somethimes if i really step on it, it will stall and do like a backfire, well its kinda like a PssHHH sound coming from the engine and somethimes it kills the engine. Any ideas? Oh i will try to check my MAP sensor with service manual. and also check for any intake air leaks..
thanks!
Old Mar 25, 2009 | 09:28 AM
3D-Aircrew's Avatar
3D-Aircrew
Default Replaced O2 sensor fixed my code44
I have an 1986 though.
Old Mar 25, 2009 | 02:04 PM
djirok's Avatar
djirok
Well Ill keep checking it.. Il probobly take it to a mechanic or something!
Old Mar 25, 2009 | 05:06 PM
Rohn's Avatar
Rohn
My Haynes FSM says. Vac leak. check TB base gaskets. intake manifold lid gasket. Intake base gasket. vac hoses.
OR could be a defective 02 sensor.
Old Mar 25, 2009 | 08:44 PM
djirok's Avatar
djirok
hey know what I think about it.. I do hear some kinda hissing coming from a hose around the TBS, but I cant figure where exactly it is coming from..
Old Mar 25, 2009 | 08:45 PM
djirok's Avatar
djirok
is a hissing noise normal on crossfire engines?
To My 84 Vette Check Engine need help
