Never hung out here..
Old Nov 18, 2009 | 08:28 PM
  #41
COPO's Avatar
COPO
Could not find a PS reservoir that would fit and have the mounting tabs and outlets where I need them. So I had to make one.
Old Nov 19, 2009 | 07:55 PM
  #42
neat's Avatar
neat
Great looking project man. I can't imagine the hours...
Keep it up!
Old Nov 20, 2009 | 09:04 PM
  #43
COPO's Avatar
COPO
Keep it up!
I just need longer days Started the IC today. Making a front air dam to feed more air into the front. Made the lower radiator support about 3 inches shorter. Will gain about 60 sq inches for cooling.
Old Nov 21, 2009 | 07:27 PM
  #44
COPO's Avatar
COPO
Got most of the lower air dam made. Just some small filler peices to be made.
You can see where the old spoiler was. It will be trimmed off to let more air in.
Old Nov 21, 2009 | 08:44 PM
  #45
93 ragtop's Avatar
93 ragtop
The air dam is nice, but the hood scoop is really a work of art!!
Old Nov 22, 2009 | 03:37 AM
  #46
mnstrlt1's Avatar
mnstrlt1
I think the Dyson vaccum might "finally" have some competition! lol... this is serious a sweet project. Can't wait to see if come together.
Old Nov 23, 2009 | 07:14 PM
  #47
COPO's Avatar
COPO
Thanks!! If works out as planned, the hood will be functional.
hwy temps are down atleast 10-15 degrees.
Old Nov 25, 2009 | 08:07 PM
  #48
COPO's Avatar
COPO
Adding to the radiator shrould for a lil more air.
Old Mar 29, 2010 | 03:33 AM
  #49
dmukina's Avatar
dmukina
Im a little upset that i only JUST found this thread! Any progress?
Old Mar 29, 2010 | 10:14 PM
  #50
COPO's Avatar
COPO
Not as much as I would like!!!! I got the fiberglass done on the shroud. Got to do the finish work as I am having it sent off to be made out of CF if possible. Done a little work on the cold side. Just have a long list of parts to buy.
Old Mar 30, 2010 | 08:48 AM
  #51
red L98's Avatar
red L98
hey can i get some info on ur intercooler ?
size , pics, and who built is and if u dont mind the cost .. thanks
Old Mar 30, 2010 | 08:47 PM
  #52
COPO's Avatar
COPO
Since this is a limited budget I went with a cheaper one with cast ends. I can measure it and let you know. Its not a good pic but the only one I have.
Old Mar 31, 2010 | 09:54 PM
  #53
COPO's Avatar
COPO
32x16x3 is the size. I did have the cfm flow but its buried some where.
Old Apr 18, 2010 | 02:12 PM
  #54
COPO's Avatar
COPO
Got the shroud built. Sending it off to be made in CF.
Old May 14, 2010 | 10:56 AM
  #55
84compuvette's Avatar
84compuvette
Awesome setup! That thing is going to be a monster when you are done!
Old May 14, 2010 | 12:10 PM
  #56
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old May 22, 2010 | 06:46 PM
  #57
American Hydrocarbon
Guest
Posts: n/a
COPO your car is amazing.....
Very nice body work!
To Never hung out here..
Old May 22, 2010 | 10:45 PM
  #58
mnstrlt1's Avatar
mnstrlt1
Man- I'm impressed with that shroud! what was the process?
Old May 24, 2010 | 08:17 PM
  #59
COPO's Avatar
COPO
You are only seeing half of the build. Suspension/brakes/ Tires & wheels havent even been shown.
Thanks Pat!! Wish I could do what you can.
Started with cardboard for fitting and then fiberglassed it along with body filler. Primed a couple times and will be sent to flasunshine to be made out of Carbon Fiber. Thats the only part I need to install the motor other than coatings on the pipes and wiring harness. Which I will be calling Jared this week to figure out what I am going to do. But before the engine goes in, brakes, big tires and wheels along with some serious suspension mods will have to happen.
Old Jun 5, 2010 | 11:16 PM
  #60
COPO's Avatar
COPO
Finally got the motor off the stand and sent the hot side off to be coated. Installed the FW and the clutch. There is enuff room for the LS7 clutch but not for a fork. So a hyd throw out bearing will have to be found. This also gives me more room for down pipe. Been wanting to make it 3 1/2 or 4" so I may have room now.
