'96 Vette Power Window Question
Old Mar 21, 2009 | 01:55 PM
split-end's Avatar
split-end
Default '96 Vette Power Window Question
Sometimes the passenger power window will not work properly. It may move a fraction of an inch then stop, then I would flip the switch back and forth and then it will work. Any ideas on what could cause this symptom/problem?
Old Mar 21, 2009 | 05:09 PM
runner140*'s Avatar
runner140*
You need to pull the door panel and take a look. Might be a bad ground or bad window/glass allignment.
Old Mar 21, 2009 | 07:55 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default switch
JMO.... I would put an ohm meter on the switch to rule that out as a possibility.
To '96 Vette Power Window Question
