Changing Differential Oil...
Old Mar 21, 2009 | 08:34 PM
Corvette Chris's Avatar
Corvette Chris
Default Changing Differential Oil...
'86 L98, D36. I want to change the gear oil in the rear end before the drag strip opens back up.
Instead of dropping the differential to drain it, I was hoping to use my vacuum oil changer I use for the boat. Planned on going in through the oil level screw and sucking it dry. Anybody done this before?
Old Mar 21, 2009 | 08:42 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I know people have recommended sucking it out, I personally just drilled a hole in the bottom and tapped it then plugged it. The vacuum method should work though. Just make sure you get the hose as low as it can go to get as much of the old oil out as you can.
Old Mar 21, 2009 | 08:51 PM
Corvette Chris
I had to believe it'd been thought of before. Looks like I'll do that this week, before I hang the new exhaust.
Old Mar 21, 2009 | 09:24 PM
c4cruiser's Avatar
c4cruiser
Sucking the old fluid out is the best way. Unless you are sure where to drill, it can be a big "Oh S***!" if you drill in the wrong place .
The accessory catalogs used to carry a kit to install a drain plug and came with a template to show exactly where to drill. Don't know if they are still offered, but you can get 95% of the old fluid out even by using one of the Harbor Freight $5 hand pumps. And you use the same pump to put the new fluid in along with the GM additive.
Old Mar 21, 2009 | 09:25 PM
Corvette Chris
I briefly thought about drilling and tapping. That lasted about 2 seconds. I know my luck.
Old Mar 21, 2009 | 10:44 PM
l98tpi's Avatar
l98tpi
Max G’s
Old Mar 21, 2009 | 10:49 PM
dan6712cc's Avatar
dan6712cc
Bill from ZFDoc says not to drill it as most will eventually leak even if it's done right because of the material the housing is made of.
Old Mar 22, 2009 | 11:19 AM
Aardwolf's Avatar
Aardwolf
Simply pump it out with a hand pump, switch the hoses around and pump the new lube in.
Old Mar 23, 2009 | 11:32 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I used a fluid pump I got from Harbor Freight Tools. It attaches to a 1/4 inch drill. Similar to the ones they carry in the J.C. Whitney Catalogs. Works well and it's reversible, too.
http://www.jcwhitney.com/Auto-Parts/...FQETGgodXWjN5g
To Changing Differential Oil...
