air mix/temperature door?
Old Mar 22, 2009 | 11:26 AM
jstewp's Avatar
jstewp
Default air mix/temperature door?
I have an '89 Corvette convertible. The air mix door does not open or close. I took the programmer out and the resistors appeared to have gotten hot. The local Radio Shack dealer was unable to determine the value of the resistors. What are these values, ohms, watts and tolerance? How do I test? Where can I purchase these resistors?
Old Mar 22, 2009 | 09:28 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have a spare programmer at work. I will see what the resistance colors are.
My guess is they are 1 watt resistors. but I don't know what the resistance is.
Um, in any case, I don't know if the resistors are for the door.
I think they may be in the circuit that changes the speed of the blower.
Old Mar 23, 2009 | 09:16 PM
coupeguy2001
Default resistors
I don't have my resistor value chart handy, but here goes:
brown, gold, brown, with a silver (i think) 10% tolerance band.
and they are indeed 1 watt resistors.
i should think a ceramic resistor would hold up much better.
Old Mar 24, 2009 | 03:18 AM
samsonb's Avatar
samsonb
The door is probably just stuck. I had the same problem when I got my 89. I would get AC, but when I turned to heat, I could tell I had heat, but it wasn't blowing. Looked through the resistor hole, and noticed the temp door didn't change when I turned from AC to heat and vice versa. I stuck a screw driver in the hole to move the door as that seemed to unstick it. Might be easier to just pull the blower motor to get in there.
Though, one problem I have is when I'm in Auto and turn the temp up to 90, it seems to shut the doors into defrost or something. In order for me to get heat through the vents I have to have it set to Bilevel. I never figured that out.
Old Mar 24, 2009 | 04:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For my '88 the resistances are:
.....A.......C........D.......B
A-C = 1.5 Ohms
C-D = 0.7 Ohms
D-B = 0.2 Ohms
Yel = wire into A
Tan = wire into C
Lt Blu = wire into D
Dk Blu = wire into B
Using P = I*V & V = I*R or P = V**2 / R and assuming a max voltage of say 15Vdc, you can calculate the wattage required for each resistor.
With the blower speed set to:
Lo = power through Yel wire and all resistors
M1 = power through Tan wire and C-D + D-B resistors
M2 = power through Lt Blu wire and D-B resistor
Hi = full battery voltage applied to blower motor
To air mix/temperature door?
