what head bolts to use?
Old Jan 28, 2002 | 09:35 PM
dtorc4's Avatar
dtorc4
Default what head bolts to use?
I have AFR 190 heads. I see in the summit catalog that the head bolts are listed for particular heads. Is there a certain type I should be looking for or will any head bolt work? :confused: :cheers:
Old Jan 29, 2002 | 02:51 AM
ol,RJ's Avatar
ol,RJ
Default Re: what head bolts to use? (dtorc4)
a 12 point (instead of the reg. 6point) kit will work best. the only problem is its very close to the valve springs on one or two of the holes, thats why you should use the 12 point bolts, it lets you use a regular thin wall socket.
Old Jan 29, 2002 | 03:11 AM
BobMachus's Avatar
BobMachus
Default Re: what head bolts to use? (ol,RJ)
ARP stainless grade 8. It won't pay to skimp here. :nonod:
Old Jan 29, 2002 | 03:24 AM
drive it's Avatar
drive it
Default Re: what head bolts to use? (BobMachus)
Ditto to ARP.
Old Jan 29, 2002 | 09:59 AM
-=Jeff=-'s Avatar
-=Jeff=-
Yep.. 12pt ARP bolts
or go crazy and do ARP Head Studs
To what head bolts to use?
