Brake Question?
Old Mar 22, 2009 | 11:11 PM
blackvett09's Avatar
blackvett09
Default Brake Question?
I had to replace me rear brake pads and rotors. Does anybody know what the torque spec's are to the bolts that hold the caliper bracket and the caliper bolts that hold it to the caliper bracket? My vett is a 93. Thank you.
Old Mar 23, 2009 | 04:58 AM
toptechx6's Avatar
toptechx6
Bracket mounting bolt torque is 70 ft.lbs, the guide pin bolt torque is 26 ft. lb for the upper and 16 ft. lbs for the lower.
