Transmission Help !!!!!!!!!!!!!!
Old Mar 23, 2009 | 12:19 AM
GR Motorsports's Avatar
GR Motorsports
Default Transmission Help !!!!!!!!!!!!!!
I need help desperately. The last few days i've noticed that my trans only shifts at very high rpms. Now it wont shift into 3rd(not even manually). When i checked the trans fluid (after running it for about 20 min) it looked low but after a half hour it looks ridiculously high. This is my DD so I need to figure this out quickly. Thanks for the help.
Old Mar 23, 2009 | 12:21 AM
Pete K's Avatar
Pete K
You lost the 3-4 clutch pack. Rebuild time.
Old Mar 23, 2009 | 04:15 PM
GR Motorsports
Someone was telling me that this is either caused by the excess amount of trans fluid or a problem with the vacuum line. Could this be the problem?
Old Mar 23, 2009 | 07:07 PM
Pete K's Avatar
Pete K
Your trans does not have a vacuum line.
The only way a trans can have too much fluid is if you over filled it, or the radiator cooler ruptured and filled the trans with coolant.
If you overfilled it, drain it down.
If it overfilled itself, order a new radiator before you overhaul the transmission.
Old Mar 23, 2009 | 07:16 PM
GR Motorsports
A few weeks ago my electric fans stopped working and the car started to overheat and coolant forced its way out of just about every hose so is it possible some got into the trans? Thanks for all your help Pete.
To Transmission Help !!!!!!!!!!!!!!
