Torrington bearing?
Old Jan 28, 2002 | 09:49 PM
dtorc4's Avatar
dtorc4
Default Torrington bearing?
What does this do and is it necessary on the timing chain? Can it be used w/ factory roller cam? Thanks. :cheers:
Old Jan 28, 2002 | 10:26 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Torrington bearing? (dtorc4)
Torrington is a brand name. They make bearings mostly associated with straight rollers. I've known several types of "needle" bearings refered to as "Torrington". As related to the cam drive, it is a flat washer with rollers inserted, radially. The rollers protrude beyond the cage (washer) and roll against hardened flat surfaces (races) both in front and behind the "washer". It is a thrust bearing. Flat tappet cam lobes are ground on a front to rear taper to induce tappet rotation. The tapered lobe "forces" (rearward thrust) the camshaft in to the the block. The Torrington bearing reduces the friction the thrust causes between the cam sprocket and the block. Under extreme conditions, the cam sprocket can "eat" into the block. Stock Chevy engines don't use them, and therefore many don't feel that they're needed. In most applications they aren't. Hot rodders, being who we are, often go for the "overkill". Besides, there is a nit of horsepower liberated by the reduction of the friction. Roller cams are NOT ground with the tapered lobes and therefore have no need for a thrust bearing. Is that about as clear as mud? I know, you asked for the time and I told you how to build a clock.
Old Jan 28, 2002 | 10:32 PM
bogus's Avatar
bogus
Default Re: Torrington bearing? (CFI-EFI)
crystal... but such a lovely clock... :D
I did not realise that Torrington was a brand name. I always associated it with thrust bearings.
[Modified by bogus, 9:33 PM 1/28/2002]
Old Jan 28, 2002 | 10:35 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Torrington bearing? (bogus)
Kind of like "clear cellophane tape"?
Old Jan 28, 2002 | 10:39 PM
dtorc4's Avatar
dtorc4
:eek: :eek: Could you repeat that again... I didn't catch it the first time :jester Thanks CFI!
To Torrington bearing?
