Hey everyone, check engine light lit up on the way home today after havin a rough idle and running a little sluggish. Sooo, looked up the code. H44. runnin lean 02 sensor. So my question is which sensor is correct for me to buy in order to replace? I looked up a few to get some prices, but im not sure which one is best.
I am just not sure which one is correct, I know ecklers would work but its more expensive and I dont know if its worth buying if there is better out there for cheaper. thanks for any input
Reason: spelling
I have had the same problem in the past. Bosch worked just fine for me. They were about $50 at Autozone. Just for FYI A sticky EGR valve was the culprit causing the O2 sensor(s) to trip. I took it off, cleaned it really well with carb cleaner until it moved without sticking and put it back on.
a while back I was getting H32 which had to do with the egr valve. But it would come on randomly and than never again. Maybe ill take a look at the egr valve first before i buy the O2 sensors. Than again, i still wanted to replace my 02 sensors. Ill check the EGR first anyways
