std or high volume oil pump.
Old Mar 24, 2009 | 11:43 PM
chadihrig121's Avatar
chadihrig121
Default std or high volume oil pump.
mild 350 lt4 rebuild. (around 350 horse) Can I run a high volume oil pump with this set up with the stock oil pan? are all sbc oil pumps the same or is it different on ltx engines? can i just go with the melling 155hv?
Old Mar 24, 2009 | 11:54 PM
STL94LT1's Avatar
STL94LT1
I've always read don't use a high volume pump with the stock pan on the LTx engines.
Old Mar 25, 2009 | 12:10 AM
rodj's Avatar
rodj
Extra flow not needed
Read
http://forums.corvetteforum.com/c4-t...oil-pumps.html
Old Mar 25, 2009 | 05:54 AM
Calderone's Avatar
Calderone
STD !
i did a research on this also,and went with std pump
On John Lingenfelter's book he also favors the std pump
Old Mar 25, 2009 | 08:18 AM
HiTech5's Avatar
HiTech5
I use the Lingenfelter recommendation on my motors. Std volume but I change the spring to a high pressure. Works great!
Old Mar 25, 2009 | 08:21 AM
Calderone's Avatar
Calderone
damn i installed with the same std spring
why was the HV spring for ?
Old Mar 25, 2009 | 09:51 AM
Elephanthead's Avatar
Elephanthead
Lingenfelter website's price is cheaper then autozone for the M155. They sell all you need including the spring if you want it.
To std or high volume oil pump.
