Idle with new Cam?
Old Mar 25, 2009 | 11:37 AM
rickneworleansla's Avatar
rickneworleansla
Default Idle with new Cam?
I'm wondering where everyone has their idle set with an aftermarket cam. The one I installed has a pretty good lope to it. It's definately not a hotcam. In the new tune it appears to be set to idle at 850 rpms. Would lowering it some be a good idea or just make it kill? See signature for cam specs and mods.
Old Mar 25, 2009 | 11:57 AM
aklim's Avatar
aklim
Why not talk to the person burning your chip? Them and the cam manufacturers will have a better idea.
Old Mar 25, 2009 | 02:50 PM
STL94LT1's Avatar
STL94LT1
Rick, I'm running an M6 with a 224/230 605/622 112 camshaft, and have my idle set at 800 rpms. I don't like the idle set so low that it sounds like the car is going to stall when idling. Yor camshaft has a tighter LSA and your running an A4. So, 850 rpms sounds about right to me. Don't know if you do your own tuning? But, it only takes a couple if minutes to change the idle and see what happens.
Old Mar 25, 2009 | 03:43 PM
JAKE's Avatar
JAKE
I don't recommend you try to lower the idle speed. Due to your cam, you need the higher idle. Don't concern yourself with a hundred (100) RPMs at idle.
I agree, too, that your cam calls for that idle speed due to its duration and LSA of 109.
At the current idle speed, your idle shouldn't be too raunchy; mine's only noticable and listeners actually have to spend a little time to actually hear that it's different from stock.
Since this is the second time you've mentioned this issue, I'm now suspecting that you may have a vacuum leak or a too tight lifter preload adjustment. If it turns out that you don't have either, you'll have to chalk it up to the 109. Comes with the territory.
Remember, most of our aftermarket cams are on 112 or higher LSA. That decreases the over-lap and smooths the idle. Some guys like the tighter LSA because of the peakier torque curve it gives, but there's a trade-off - Isn't there always?
Jake
West Point ROCKS!
Old Mar 25, 2009 | 05:08 PM
LD85's Avatar
LD85
I set my 233 cam to 950 rpm then moved it up to 1000rpm.
I agree, I would not go lower
Old Mar 25, 2009 | 05:15 PM
blue94's Avatar
blue94
running the same TC and cam is almost identical 1 degree LSA is the diff and I am at 900 idle...don't go lower than you are at.
Old Mar 25, 2009 | 05:23 PM
rickneworleansla
I think it's just that I have not been in a car with a cam in so long that I am not used to it. I'm used to the Vette being fairly still at a redlight. My 67 had a cam but it's been so long I forgot how it felt. Of course it also had an exhaust system that probably tamed down the experience a bit. Whats the best way to track down any vacuum leaks, just in case? I did request a cam with a heavy lope. I'll get used to it.
Old Mar 25, 2009 | 05:37 PM
96GS#007's Avatar
96GS#007
Squirt a little starting fluid around the edges of the intake and listen for rpm surge. I doubt you have any vacuum leaks.
FWIW, many of the factory cams have an LSA of 115* or even 117*, not to mention less duration than what you have.
blue94's Avatar
blue94
With an LSA of 110 mine is not perfectly still either but close you are at LSA 109 so yours will be more pronounced. still it should not shake badly.
For me, finding a leak without a smoke machine is a PITA unless you know what area is suspect. If a gasket leak do what 96GS#007 says.
Old Mar 25, 2009 | 07:55 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
my 396 with 230/236 114 lsa is set at 825. i have played with the idle, and with an automatic I prefer 825 right now.
To Idle with new Cam?
