Painting the computer
Old Jan 29, 2002 | 07:19 AM
C4SMAJ's Avatar
C4SMAJ
Default Painting the computer
I just had the fuel rail covers.. overflow tank.. air cleaner housing and a few other things painted Pearl White....Im real happy with the way it looks...now that computer sure looks bad...Ive polished on it but its still ugly.....Im thinking of having it painted white to match the rest.....anyone see any problems with this....my concern is heat....I know it gets hot...and I just wonder if by painting it... it may not get rid of the heat.......as well as an unpainted one......any thoughts...?????
Old Jan 29, 2002 | 07:56 AM
Carroll B's Avatar
Carroll B
Default Re: Painting the computer (larryf)
How much did it cost you to have the items painted? I have been thinking about getting my fuel rail covers and overflow tank done.
Old Jan 29, 2002 | 08:44 AM
C4SMAJ's Avatar
C4SMAJ
Default Re: Painting the computer (Carroll B)
my neighbor did it for me...he's a paint and body guy by trade....he did the air cleaner housing..radiator overflow, cruise control cover, both fuel rail covers ... the cooling system expansion tank (not the overflow).. the power steering resevoir and the plastic plate on top the TB...for $100...he sanded everything smooth got rid of all the casting flash etc...especially on the rail covers....they have that ruff look...those are now smooth and really look nice....he used the pearl white that Lexus uses..anyhow it was a 3 step process to paint it....primer...base coat and clearcoat.......really brightens up the entire engine compartment.....now if I can just figure out what to do with that computer and the A/C and altrenator..........
Old Jan 29, 2002 | 10:06 AM
TrplBlk01's Avatar
TrplBlk01
The cover is plastic yes? Gets some good plastic prep from your local paint supply shop. I see no problems with painting it just be careful and make sure it cures before putting it back on.
Old Jan 29, 2002 | 10:37 AM
C4SMAJ's Avatar
C4SMAJ
Default Re: Painting the computer (blk91)
no the cover is metal.....Im concerned that if I painted it the paint would act like an insulator.........
Old Jan 29, 2002 | 11:45 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Well, it's painted black already. I don't see that it would hurt. I painted mine with the valve cover paint when I did the intake work, looks okay.
Not the best picture, but the only one I could find....
Old Jan 29, 2002 | 12:35 PM
KCvetteowner's Avatar
KCvetteowner
I know what you're talking about...the computer cover is dull metal. I took mine apart and polished it using Mother's and some felt pads and now it's somewhat shiny (polished aluminum). I didn't have enough time before a show to really do it perfectly but maybe now that we have a winter storm watch it's a good time to take it all apart again.
As to your question, I've seen some that are painted and I know your instinct is that it would be an insulator, I think it would be too. Are you thinking of painting both sides or just the top?? The computer is in the engine compartment anyway so it has to be able to take heat. GM put it in a metal box with a rubber gasket so their is no internal airflow. I would think the thing is going to get hot anyway and a coat of paint on it won't make much of a difference.
Old Jan 29, 2002 | 01:38 PM
C4SMAJ's Avatar
C4SMAJ
Default Re: Painting the computer (KCvetteowner)
thanks for all the input guys.....Craig mine is a 96... the computer housing is different than yours...mine is cast aluminum with cooling fins etc...its more of an integrated unit than just a box type cover....anyhow after reading KCVETTEOWNER's post I may try to take it apart like he did....I didnt think it came apart.........and do some polishing on it...i polished while it was still on the car and it really didnt do much.......tks again.............
Old Jan 29, 2002 | 02:15 PM
KCvetteowner
Good luck to you...
It does come apart. The rubber gasket is a little sticky but a putty knife or screwdriver will help and just pull it apart. Try to avoid touching the computer board as much as possible. The fins are a PITA to polish but it's possible. I rolled up sandpaper to smooth it out (600 grit, then 800 grit and then 1200 grit, finally Mother's). I need to spend about 4 more hours on it to get it all looking near perfect, I still have some pits in the metal and areas around groves I need to use my dremel tool on.
Old Jan 29, 2002 | 02:35 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Just use high heat engine paint... or see what the temp specs are where you got them painted...
Old Jan 29, 2002 | 02:40 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
YUP, HERE IT COMES :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Old Jan 31, 2002 | 08:16 AM
C4SMAJ's Avatar
C4SMAJ
thanks KCVetteowner....this is gonna be my project for this weekend.....
Old Jan 31, 2002 | 11:21 AM
merrick's Avatar
merrick
Hey neighbor, Another idea is to bead blast it and spray it with some clear. That would be easier on the fingers and no more polishing. Post some pics when you get the engine bay done. Or just come on over. :flag
Old Jan 31, 2002 | 11:47 AM
C4 4Me's Avatar
C4 4Me
Cruise-In II Veteran
Default Re: Painting the computer (merrick)
Why risk damaging a very expensive computer purely for looks??
Old Jan 31, 2002 | 01:10 PM
HighHopes85's Avatar
HighHopes85
Check with the Eastwood Company (eastwoodco.com???). I know that there is a paint specifically made for radiators that is used on the fins and is *supposed to increase cooling efficiency. The problem is...I don't know if they make a color other than black. -Matt-
EDIT-http://www.eastwoodco.com/cgi-bin/sg...UREQA=1&FNM=20
[Modified by HighHopes85, 11:16 AM 1/31/2002]
Old Jan 31, 2002 | 02:04 PM
jay17's Avatar
jay17
larryf, do you have any pics to show us?
Old Jan 31, 2002 | 02:25 PM
C4SMAJ's Avatar
C4SMAJ
Default Re: Painting the computer (jay17)
I got a couple pic's but no way to post...Ill have to work on that.......
To Painting the computer
Old Jan 31, 2002 | 02:47 PM
GlockLT4's Avatar
GlockLT4
Default Re: Painting the computer (Marcho Polo)
94+ aren't painted .. they are an aluminum alloy casing, that's it.
Old Jan 31, 2002 | 02:51 PM
scorp508's Avatar
scorp508
I would be careful with that. You would not want to reduce any heat disipation. Computers + Extra Heat = Bad.
Old Jan 31, 2002 | 03:07 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Do not paint it white. The ecm will run hotter with white paint on it which is not a good thing. The reason it will run hotter is that the case is supposed to dissipate heat from the electronics. White paint reflects heat which sounds like the ticket to keep out engine compartment heat but remember that the paint is also white on the surface of the paint coating facing the inside of computer. That means it will reflect the heat from the computer back and reduce the effectiveness of the ECM case to dissipate heat.
I would leave it alone.
