Hello corvette world.I need to replace my rear hubs and wondered how hard and if there is a how to guide that someone can post on here.I've searched the forum with no luck.Thanks
Not hard, but the star bolts are a bitch to get out, you will most likely need an impact wrench(unless you are a gorilla).
Other than that, it is easy.
Take off tire, brake caliper, rotor and axle nut, then take off the 3 star bolts.
Some people take off the tie-rod, I had an impact with extensions so it was not that hard to take off.
Been a while since I did mine. But make sure you have a few swivels and extensions. Took a little bit of playing to get to the bolts on the inside of the hub, other than that it was pretty strait forward. I didn't even need a puller to get the hub off, just slid right off.
Do yourself a favour and crack the hub nut (36mm) loose before jacking.Remove the center cap and loosen while the weight of the car is still on the wheel.
165+ ft/lbs plus rust means they don't undo easy unless you have a air gun
Buy them here OEM Delco's $100 http://www.corvetterecycling.com/product_p/7470501.htm
Thanks that is where i ordered them.Real good price.
