Engine harness question 1990 L98
Old Mar 25, 2009 | 03:35 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Default Engine harness question 1990 L98
I was looking in my FSM and it shows 3 grounds going to the back of the bellhousing on the passenger side. I remember the ones on the driver side, have them taken care of. I cant find any on the passenger side, and I dont remember any being there when I pulled it apart.
So, should they be there?
Old Mar 25, 2009 | 04:13 PM
jeffp1167's Avatar
jeffp1167
mine has a good 5 grounds going to the rear of the drivers side head.
Old Mar 25, 2009 | 04:25 PM
mseven's Avatar
mseven
I was looking in my FSM and it shows 3 grounds going to the back of the bellhousing on the passenger side. So, should they be there?
my 90 has none on the pass. side trans/bellhousing. The bottom 2 bolts in the case on that side have brackets for stater wiring, est, and water temp., and positive battery lead to stater.
Old Mar 25, 2009 | 04:30 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Same here.
Originally Posted by mseven
my 90 has none on the pass. side trans/bellhousing. The bottom 2 bolts on the case on that side are for stater wiring, est, and water temp., and positive battery lead to stater.
Thats exactly what Ive got. Thanks again.
To Engine harness question 1990 L98
