the best thing i can think of is not spill gas all over your self. this will help with the top nut( one of those open end wrench bits for a socket wrench and a long extension will work)dont forget to unscrew the gas cap first and bleed the fuel line at the fuel rail. small things yes but some how seem to be forgotten and you will be much happyer if you dont have to wash gas out of you hair and eyes and wipe up a big mess, just for a filter change. i have done it myself and have seen it done too many times, even at a auto shop.
I have changed the fuel filter on my '86 coupe several times. Using a flare nut wrench helps. You can ease the pressure by turning the nut and letting the gas run out in a pan. Then taking the filter off and putting the new one on is pretty straightforward.
Boy, do I agree...the last time I did it on my '89, I THOUGHT I had relieved the pressure (pulled out the fuse and let it run to stall) but ended up with fuel all over my arm. So, just be sure to let the pressure out!
On my 95 convertible I unbolt the bottom nut and disconnect the lines from the engine. I can then pull the filter out from the bottom with the lines still connected. Very easy. Check to see if you can do the same with your year.
It is not only the pressure .
Tank is higher than filter so it will siphon out anyway.Change filter with min fuel in tank or disconnect the supply line under the filler cap.Then you only have to drain the line from tank
I just did the SAME exact thing last week. Make sure you pick up a pack of brown fuel safe o-rings from autozone for your fuel lines, one on either side of the filter. One of mine was in pieces, the other smashed.
Took me weeks of failure before I figured this out. Disconnect the fuel lines, remove the mounting brackets under the frame holding the fuel lines, and lower the fuel lines down with the filter. Makes the job a lot easier.
This is what I do. Amazing I'm still alive with fuel running down my arms and shirt with a trouble light under the car... A few of these episodes and I decided to get smart and be safe.
Its a piece of cake to do as long as you use 2 wrenches of the correct size and then the whole fuel pressure thing, you'll get fuel on you regardless but better for it to be a drip than a big spray
And buy yourself flare nut wrenches as mentioned, it's easy to round the nut off with regular wrenches. Made that mistake once, never again...
Been there , get to wise up pretty quick in those situations
Originally Posted by Driver84
The method I have used to bleed fuel pressure in the past is pulling the fuel pump fuse, starting the motor, and letting in run out of gas.
Read what I said above.That only removes the pressure from the line , not the fuel itself. Fuel will still siphon out , especially if you have any volume in the tank.
Best tip I can add is for you to remove the fuel pump fuse, start the engine, then let it run until it dies from fuel starvation. Then, remove your fuel filler cap to relieve any pressure in the tank.
In this manner, you'll have less than 1/4 of a cup of fuel in the line to trickle out after you loosen the fuel filter. Get a jar and some shop towels to collect and contain the excess fuel.
Next, unhook the negative battery cable before loosening the filter for safety. You'll be working in close proximity to the starter, knock sensor heat shields, and other metal parts and it's all too easy to introduce a spark by contacting the starter solenoid with your wrench or other tool.
That's what I do. I little still comes out but not enough to be concerned with. No big deal.
I tried that several years back the first time I needed it replaced. They could not figure it out. A later C4 vert filter is hard to get to with the stock cat. I went home, posted on the forum, received a how-to, and replaced it myself the same day. I went back a week later to the shop and taught them how to do it. Gotta love this place!
