'870 to '165 ecu conversion questions
Old Jan 29, 2002 | 10:51 AM
johndezman's Avatar
johndezman
Default '870 to '165 ecu conversion questions
for those that have changed computers...
1.) the eecis.udel.edu/~davis/z28/ecms/ page talks about "repinning".
from the instructions the pinned leads are removed from one connector and relocated to another position of another connector, if i understand correctly. there is no mention of installing a new pin.
do i understand this correctly?
to me repinning means remove the old pin and install a new.
2.) what is the total amount of time for the repinning/splicing (assuming the harness is on a workbench, disregarding time to access the parts in the car)
again, thanks for everyones help - this is a great resource for the hobby!
Old Jan 29, 2002 | 11:39 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: '870 to '165 ecu conversion questions (johndezman)
John, I'm going to move this to the ECM section where you'll get more info!
Old Feb 5, 2002 | 11:13 AM
johndezman's Avatar
johndezman
ttt
can anyone give me an idea of the "bench time"
Old Feb 11, 2002 | 05:30 PM
Warlock's Avatar
Warlock
I just converted from a 165 to a 730... took me about 4 hours.
The easiest way to do it if you are not goint to keep the ability to run the stock computer (like I did) is to re-pin. Remove the pins with the wires on them from the current connector and slip them into the new ones. Some people re-wire and call it re pinning. I did both.
[Modified by Warlock, 1:33 PM 2/11/2002]
To '870 to '165 ecu conversion questions
