93 auto help
Old Mar 27, 2009 | 12:41 PM
mikeremax's Avatar
mikeremax
Default 93 auto help
I have a 93 with a lt . The Throttle Body open have way or a little more is this right?
At low speed 20 to 40 mph If I floor it does not down shift it will pick up speed. I feel like it should down shift. It just had the tv and gas cable ajust at the local chevy dealer. Thanks for you help.
Old Mar 27, 2009 | 01:53 PM
toptechx6's Avatar
toptechx6
The TV and throttle adjustment procedure is unique to 92 & 93 Corvettes, they are the only years that have a TV cable and ASR, the adjustment is made at the ASR servo. I can e-mail you the pages from the FSM if you want to attempt it yourself, you will need an inch pound torque wrench and a 1/8" drill bit, PM me if interested.
If you choose to return to the dealer make sure they are aware of the special procedure, these cars are old and they may not have a tech who understands that. If they adjusted it correctly the cable may be bad and will not hold the adjustment.
If you drive back to the dealer drive gently, you can damage the transmission when the TV cable is not adjusted properly.
Old Mar 27, 2009 | 03:10 PM
mikeremax's Avatar
mikeremax
PM send
Old Mar 27, 2009 | 03:11 PM
mikeremax's Avatar
mikeremax
I look at my father inlaw 93 corvette and his is just like mine.
Old Apr 1, 2009 | 11:27 AM
mikeremax's Avatar
mikeremax
I just left the shop and they think the trans. is done. Tha cable is right. I am going to change the filter is see if this help. I have let hope on this and will be with out a vette this year because of money.
Old Apr 1, 2009 | 06:54 PM
mikeremax's Avatar
mikeremax
Well I pick it. After the filter and fuild change it is shift better. They have everythink like book says.
To 93 auto help
