lt4 hotcam swap
Old Mar 28, 2009 | 03:23 PM
kaitlin's Avatar
kaitlin
5th Gear
Default lt4 hotcam swap
looking to do a cam change on a 92 before i do it im trying to find out
whether i have to take aluminum heads off and have them machined or can i just
change springs to accomadate cam what would be good springs to get
I plan on getting edelbrock base for tpi already have slp runners
car is a manual any help is appreciated
Old Mar 28, 2009 | 03:37 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
If you are running 113 heads, I'd go with the LT4 springs. They should be a direct swap, same springs that come with the hotcam kit.
http://www.sdpc2000.com/product/1249...SpringKit.aspx
Old Mar 28, 2009 | 04:14 PM
STL94LT1's Avatar
STL94LT1
FYI: The 92 Corvette was an LT1, no TPI and SLP runners.
Old Mar 28, 2009 | 04:27 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Im pretty sure he has an F-body.
Old Mar 28, 2009 | 04:29 PM
STL94LT1's Avatar
STL94LT1
Then why is he in the Corvette C4 section with no profile/signature filled out!
To lt4 hotcam swap
