Lowering Retainers
I believe its from the pressure of the spring when you tighten the bolts.
heres the difference in the two brackets
late model on top
Close up of Spring and the first bracket that broke as I closed up the gap at the wedge.
Also heres a picture of the First wedges or what came stock on the 85
Does the FSM say to just Strart the bolts on the retainer and then Install the control arms and shock, Then tighen the retainers?
Im ready to give up!
http://forums.corvetteforum.com/c4-t...ll-w-pics.html
http://forums.corvetteforum.com/c4-t...-lowering.html
Don't give up. It took me over 2 weeks to do what some consider a 4 hour job. I had a lot of help from people on this forum and referred to the FSM more than once. PM me if I can help.
Kim
While the suspension was under load I did all of the final torquing. I torqued the sway bar bolts, the lower control arm bolts, and the spring retainer nuts. My FSM helped in this process but I couldn't have done it without the help of Aardwolf, Weav'sVet, Epimax1, and a bunch of other guys here and on other forums. Just keep asking questions until you get it done.
Good luck, Kim
The Wedge pad which is about 1/4" thick, only the very inboard side of the the wedge is touching the frame. From this veiw it appears that the pad is not touching But it is on the insde part of the wedge.
The retainers are not to long, and there are NO screw causing it to sit Lopsided.
In this shot Looking at the frame abbove the pad,
The frame dosnt seem to be straight across from Front to rear.
Im guessing thats why chevy Used the thick aluminum Shim between the frame and the retainers
This is the Drivers side, I dont think The Bracket is to Short as the Pad is not seated on the frame all the way across, At least on the outboard side of the wedge,and the retainer bracket still bent.
The white stuff Is lithium Grease by the way.
Dont know if you can see the bend in the retainer but it is there.
Passanger side
Im not a complete Idiot, But I certainly dont understand this process, Im going to order new wedges and brackets one more time.
Anybody live close to Brooks Georgia?
Maybe if nothing else this will teach somebody what not to do.
Anybody have a stock set up for an 85 ( spring and all)?
I installed the driver side, then using a floor jack i jacked up on the very end of the spring install the retainer and bolts on the passanger side.
Here is a picture to illustrate:
There is a bump sticking down on the outboard side of the frame of just over 3/16", the single shim there is 3/16". Next there is another bump sticking down a lot more, illustrated by the horizontal shim. I think you need more wedge in there.
Check by sticking your finger up around the top of the spring and find that frame bump. You can also stick a hack saw blade between the shim as a probe.
Here are two pictures of mine buttoned up:
I'm very close to the absolute minimum wedge that can be used without the spring hitting that inboard frame bump. Just under 1/8" of clearance with the amount of wedge shown, two shims at 3/16" each. Plus 1/8" of rubber left on the spring.
Are you just using pieces of aluminum 3/16" thick Cut to size for your shims?
It's 1/2" thick and if you don't want to mess around fitting things, should be consider minimum shim needed. I won't use those after seeing how CentralCoaster's shim squashed. You can see where it was rubbed by the inboard frame bump:
Had I needed to make some shim I'd have just got some flat stock from town.
