OK, I put the gauges on the AC lines. (Thanks to SunCR) I jumped the cycle switch and got the compressor going. Here are the readings. Low side 30 psi,,High side 220 psi at 72* F with 81% humidity. How does that sound ?
Until SunCR checks in I will comment that according to the pressure chart in my 93 book your pressures look fine, this assumes an R12 system. As theadmiral94 asked the only missing part of the equation is the discharge temperature?
Assuming R12 and that the Main Fan was running (disconnect the switch) and the compressor was churning with an engine speed of 1500 to 2000 rpms, you could live with it and it isn't going to cycle as frequently (with lower ambients), but it might be a tad too much. I like 26 to 28 psi at 70 degrees (but you might not like the cycling you'll get at 60 or lower). I'd do a couple of things: 1. Make sure the Low Pressure Switch is set correctly. Hook you gages back up and with it on Max, disconnect the blower. That should drop the low and it should cycle off at 25 psi. If not, the Low Pressure Switch has an adjustment screw between the terminals. Turn it counterclockwise to lower the threshold; clockwise to raise it. 2. Get your pressures & vent temps again when it's 80, maybe 85 or better - if the vent is still good and the high isn't climbing north of 250 psi, it should be ok - sounds like you did a good job - congrats!
Thanks Bill, I will probably have some warmer weather this week and will try your suggestions.
