dtc p1441 1996 LT4
Old Mar 29, 2009 | 01:31 PM
bgrant_12002's Avatar
bgrant_12002
Default dtc p1441 1996 LT4
on my LT4 96, code keeps coming up despite finding no vacuum leaks, and a new evap purge solenoid. After resetting the code, it takes a while of driving around to get it to come back on. Gas tank holds good pressure, when I take cap off there's a whoosh sound so I doubted it's that. On both evap purge solenoids, old and new, when I disconnect the lower of the vac lines, it's continuously sucking air. What should I replace next, the evap pressure control valve in the R rear or at the evap purge vac switch in front of the solenoid-- or elsewhere? thx
Old Mar 30, 2009 | 08:01 AM
toptechx6's Avatar
toptechx6
Did you follow the diagnostic flow chart in the FSM or just replace parts based on the code?
Old Mar 30, 2009 | 10:03 AM
bgrant_12002
dont have the FSM yet. Will get it later this wk. I was just replacing based on the p1441 code.
Old Mar 30, 2009 | 10:35 AM
toptechx6's Avatar
toptechx6
I would wait for the FSM and follow the flow chart for the code, good luck.
Old Apr 4, 2009 | 08:58 AM
TWISTERUP's Avatar
TWISTERUP
I had this code about a year or so back...I removed the old purge valve blew thru it and found it stuck open....replaced the valve,cleared codes..4-5 days later ck eng. light back on-- same code--removed the new purge valve---stuck open....hmmmmm seems i had forgotten to check something I'd learned years ago and had seen more then once since...when the ecm commands the purge valve open it pulls directly from the evap cannister...the cannister had come apart internally and when the purge valve opened little bits of charcoal were sucked into the valve causing it to stick open and bingo p1441.
the fix was replacing the cannister---used a battery and jumper wires to hold the purge valve open..blew thru it with shop air to clean it out so that it was closed with no voltage as it should be...I then used air to blow thru the line between valve and cannister to clean the line and installed new cannister.
Here's the "test" remove the purge valve..lay a clean paper towel on the floor and lightly tap the valves nipples on the towel...if little black "bits " show up on the towel..then cannister is likely bad...not sure if the FSM is specific on something like this...but try it and post back on the results....Good Luck
Old Aug 14, 2009 | 04:47 AM
JimsCorvettes's Avatar
JimsCorvettes
My fix to the P1441 code on my 1996 LT4 was I to install a new evap canister. It’s located on the passenger side on the car, next to the fuel tank. To get to it you have to remove the inner wheel well shroud.
Once the old can was out I disconnected the tube (hard plastic) that ran from the can (rear of the car) to the valve just off the engine. Disconnected the line from the valve as well. I blew compressed air through the line and saw a black puff of dust come out. Now the line in basically clean enough (I hope).
I then installed the new can. (Also bought 4’ of 7/16 line to replace the deteriorating line in the engine compartment) Even though the can was an OEM part, the mounting tabs did not align up exact but I managed to get it good enough so the mounting strap on the car was able to hold the can in place.
I have driven the car for over 200 miles and wala, no P1441 code!
Last edited by JimsCorvettes; Aug 16, 2009 at 06:38 PM. Reason: The error code came back..... I knew I should have waited to post! When I have solved it I'll post again. I agree, PITA..
Old Aug 16, 2009 | 12:20 AM
jtc44's Avatar
jtc44
Default EVAP codes
EVAP codes can be tuff to get \\\rember it sometimes takes two trips or moore to get ECU to go thrugh the tests all info given by others was very good EVAP probs. are a PITA!!??
Old Aug 21, 2009 | 10:33 AM
wzschirnt's Avatar
wzschirnt
I know this thread is finished, but a tip - my canister was coming apart and sending charcoal pellets to the solenoids and sticking them open. I put a cheap plastic fuel filter in the rubber vacuum line by the front wheel well to catch the pellets. Empty (take off and tap)the filter every once in a while. Cures the symptom, not the problem, but keeps codes from being set (inspection time?).
Later.
z.
To dtc p1441 1996 LT4
