Code H15--
I replaced the water temp sensor on my '93 LT1 with no problem. I covered the opti with plastic, and a old towel over that, but in the end very little leaked out of the WP when I switched it out.
I had the new sensor at the ready, so it was a flawless swap!
Now, I'm getting a Check Engine light. I pull the code and it's a DTC 15 (Low temp indicated).
The temp on the guage is 142, even with a cold engine. The analog gauge work fine, however..
I took it for a spin to get it up to operating temp, and the digital readout stayed at 142, and the analog gauge worked properly. As soon as I started the car, the cooling fans came on (with a cold motor), and I don't recall that ever happening before.
I pulled the code again and sure enough, H15--again...
If the analog gauge is working properly, the sensor should be fine, correct? Or no?
Anyone have any suggestions/ideas/experienced this phenomenon before as well?
Thanks!
My motor has two temp sensors, one for the analogue gauge and another for the ECM.
Another friend had an issue with his A/C system, not exactly sure what the malfunction was caused by, but it was causing the ECM to think that the compressor was engaged and that turned on the fans all the time.
Thanks!
Now I remember seeing there were 2 sensors in the FSM. I've looked at so much information that it's all a blur at this point!
I cleared the codes, but the fan still turns on at ignition. I checked the sensor connection, and it looks ok. I had around 5v at the pigtail when I tested it with the multimeter, but I'm not really confident in that result. The 5v was recorded with the ignition switch in the 'off' position. The FSM states there should be 5 volts present, but I don't know if that was with ignition switch 'on' or 'off'. As you may deduct from my questions, I'm still a novice when it comes to electrical diagnosis...
Thanks!
Thanks!
I'm going to do that this afternoon when I get home. I'll let you know what happens!
Can I short them together using a paperclip?
Tech 1 but I think the digital dash display should read the same with the wires shorted together.
Thanks! I was wondering what a Tech 1 was! I figured it was something expensive that I didn't have!
I do, however, have an abundance of paperclips, so all is well!
Thanks again for your help..
Do you have any type of scan tool or did you read the code using the paper clip technique?
I used the paperclip method for retrieving codes on the speedo. I found an excellent writeup for it on another forum...
I checked temp on dash, pulled pig tail--No change 142
Jumped black and yellow on pigtail, no change...142
Jumped yellow to ground....you guessed it...no change
Multimeter on yellow to ground, key on....5 volts present..
Is this a bad ground wire perhaps? I've ordered a new sensor as well as new pigtail..
Disregard that, after doing some checking this morning on my own car I must apologize for giving you some bad information. The ECM and digital display do both acquire the temp input from the sensor on the water pump but I led you astray saying the dash would give the same reading as the Tech 1.
Apparently the CCM takes the information from the ECM then sends it to the display only if it is within a certain range. When I disconnect my sensor guess what the dash displays? Yep, 142, but it also displays 142 with the sensor terminals shorted together or grounded to the engine just like yours.
You will need a scan tool that can read the sensor values from the ECM for the FSM tests to be valid, the dash display will not work. At this point I have to believe you got the wrong sensor or a bad one. I would ohm check the sensor and compare your reading to the chart in the FSM for DTC 15. PM me if you need a copy. Good luck, sorry for the error.
I've got a new sensor/pigtail ordered and will be here tomorrow. I'll check the ohm's on the new sensor prior to installaton, and check the old 'new' one as well for comparison.
Thanks again for taking the time to help me with this! Much Appreciated!
I'll let you know how it goes!
David
David
Please do David, I look forward to hearing the outcome.
New coolant temperature Sensor arrived yesterday, and I got it installed last night!
Result: It's Fixed! No more code 15, no more SES light!
Guess I just got a 'dud' sensor the first time...
